Sounds about right to me, but out of the mentioned movements all I really focus on is the clean and press, I am trying to learn to snatch but I am finding it a very hard movement to pull off.
Hence the only real clarification from me would be in the clean and press, well the press part any way, with a mil press the bar is pressed up but slightly forward, with the clean and press the press ends with the bar straight up and the head pushed forward with the shoulders pushed back (head through the window)like a clean and jerk.
Well at least this is how I was taught to do it, I firmly believe this is the best full body movement there is, others may differ but it is my fav, it smashes me and makes me puff.
Yes I'm a fan boy, plus it scares most of the gym plebs away from the rack area where they do their concentration curls for the girls,LOL.
Clean then military press for reps is an old favorite of mine. It's good to know you can pick the weight up off the ground as opposed to from a shoulder height rack. I haven't done it seriouslyt since a single attempt earlier this year , 105kg for a few reps, vid on my training log.
The press is always head through the window style. Unless you are sitting on reclined bench or doing the 'bro' version behind the head.
  • Like 1
OK I need some clarification here on some lifts and what their goddamn f**king correct names are lol...I'll detail what I believe some they are, so just correct me if I'm wrong.
Clean
Loaded bar on ground > explosively lift bar and shrug it real high then get under it in to the bottom of a front squat position, then front squat it up to standing
Catch position of a Clean
Power clean
Same as clean, but starting from knee height a lighter weight that you can pull higher in the second phase of the lift and then a slight dip of the knees to get under it and catch it higher and then stand up.
Power clean catch position
Clean and jerk
As per clean above > Slight bend in the knees then press up through the legs hard and push the weight over head and drop to a lunge stance of sorts to get under the bar, while keeping the bar where it is to finish with it above your head and arms locked > move back to standing position
Clean and press
Same as clean and jerk, but final stage is a strict military/front overhead press from shoulder height rather than dropping your body under the bar
yep. but towards the end before it was removed from the olympics it kind of became more of a standing incline bench press.
Am I right?
Mostly
Edited by TTT
Read this in today's age for a bit of a laugh
http://www.theage.com.au/lifestyle/life/blogs/stark-naked/grunty-gym-bloke-its-time-to-shut-the-hell-up-20131113-2xfrd.html
I really couldn't care less if others grunted at the gym
Someone I know recently got banned from our gym for being too loud and doing 1RM's
Love this comment.
Omg, seriously??? If you don't like your testosterone gym, go some where else. There are now heaps of womens only gyms available. It really sounds like you are in the wrong gym. There is no need for over reacting. Also if you can't or don't want to join a womens only gym, there is also a thing called earphones. Whack one of them on, listen to your favourite tunes, and stop whining.
CommenterPaulo Location Date and time November 13th 2013, 11:17 pm
Yes ,some people really are very controlling ,and manipulative of others freedoms of expression ,arent they?
CommenterKane Location Date and time November 14th 2013, 7:12 am
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
