I only do 2 body parts per visit eg Monday chest and bi's, Tuesday Back and Abs, Wednesday Rest, Thursday Shoulders and Tri's and Friday Legs ( Shudder ) I usually do 3 sets of 8 than 3 sets of weight where im failing before 6. I usually do a min of 3 different exercises for each area.
I should add that I am currently bulking and am not doing any cardio. ( also as I typing this Im eating chicken and sweet potato :)
Edited by Kenna802
Not if you're only doing 2 or 3 exercises in the session.
I only do two or three exercises in about that time but way less volume, two unfit for that shit haha
Ah fair enough, love sweet potato. Chicken and rice with some guacamole for flavour is nice too
Damn that's fast for that amount of volume
With volume training, as you're not always lifting extremely heavy weights / at your max, you can usually shorten your breaks and pump out lots of reps. It does tax the heart and lungs if you're not used to it, though; your head will certainly spin! My diet isn't fantastic; the volume training burns through calories and keeps me trim.
Also, Leesh, when I do 2-3 exercises it only takes me 45 minutes. If I was doing your workout I would be done in an hour or just over.
Well aren't you good
Fair enough, higher volume is something I might look into next year once I've hit some of my current goals
did my 1RMs today with my gym bros - a couple of months since I stopped doing bro splits and did the PTC beginner routine. Squat 200kg, DL 170 (one half assed rep at 180 but IMO it dosen't count), Bench 110kg. Weight loss has slowed down (now at 115kg, about 1kg per month), but very happy with my strength gains. I probably could have pushed the squat a little harder, but was not sure about my knees. No wraps, belts or gloves etc, only chalk.
Working on a 120kg bench and 200kg deadlift by the end of the year.
Interestingly my bro split mates were benching 150, but couldn't keep up with squats and only just managed to keep up with deadlift. I reminded them (like I do all split devotees), that squatting is so much easier when done 3x a week.
well everyone always complains about how sore they feel after 'leg' day, or squats day; I found that squatting 3 times a week means that I never have severe DOMS in the quads, glutes or anywhere else for that matter.
Oh I see. I don't get sore from squats anymore because I cant go heavy cos of knee bending in
Give it a shot and see if you like. Good for those who like a mental slog.
This. I don't get doms either unless its after returning from a week or two off...tomorrow for example
yeah my right knee caves in as I'm coming up from the squat
It's causing a hamstring strain too
weak adductors apparently
My adductors were pretty sore for the first few weeks of squatting 3x week, It went away and so did my knee bend. Might be a correlation there but given the amount you squat it would feel like doing a weeks worth in one session.
Most likely will once I reach my goals, not sure how long that will be, next year sometime hopefully
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
