To all you deadlift mofos
You guys haven't done a proper deadlift unless you use this fat 3" bar
I've done it in the past
It def helps your grip strength and lift more and next time you pick up an generic oly bar you will think its a tooth pick
how much does it weigh?
That's ol school thick bar btw
You can get lighter thick bars
I could barely use a 3" bar cuz I'm not tall and found that a 2" thick bar was best fit and weigh a lot less than that ol dinosaur bar (under 25kg)
Yeah fair enough. I like having a 20kg bar because It's easy for me to do my sets with 20kg and 10kg plates. I have 20's on each side for warmup, I then add 10's on, then I have 2 20's, then 2 20's and a 10 either side for my max weight. Then take the 10's off and do 100kg for volume.
good stuff.
I like the gym banner btw - makes perfect sense
haha yeah, dungeon rules.. I love the gym to bits
lol I used to call my old gym the dungeon (wasnt called that but that is what I refered it to as being)
Plain and simple - no spa, no yoga / pilates mambo jumbo, no sauna, weights were very old but useful with dumbels up to 50kg (not that I ever lifted that - but 40kg I did lol)
cardio equipment - basic stuff treadmil, stepper (one of favs), cross trainer (also a good one) and bike and rowing machines)
Was a great gym - and now I just realise how much I miss it :unsure:
Not one piece of cardio at dungeon, we only got a couple of mirrors the other day too
mirrors lol
You'll probably spend more time checkin yourself out than working out
Send them back and get more weights instead
Grip used to be my problem for deadlifts, giving out before my back did, but with mixed grip and chalk it's my back that gives out first.
So I won't have a bar of it Ants...know what I'm chalkin about?
could still try it - bar costs $40
Just drop weights off and see how you go
It will improve your grip
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
