Anyone got any idea for a workout that can be completed in 45minutes or less consistently? I am pressed for time these days due to work and now training during my lunch break.
I am thinking a split system and can go 4 days a week.
Goals are obviously looks but also some strength would be nice as it would transition for sport
Would really like the main lifts squats, bench and deads in the routine as well as chin ups and either dips or machine dips
Squat, front squat, deficit SLDL
Bench, DB flat bench, weighted dips
Deadlift, BB rows, GHR
Military, DB incline, weighted chins
You've described my workout there, which is less than 45 minutes and 4 times a week...
Squats/Pullups one day
Deadlifts/Bench the next
In that order. Repeat later in the week.
I find there is little overlap unless I really push squats hard and my back is tired from them. Even then, not a big deal. I would put your dips on the bench day.
Give it a shot and see what you think?
what about shoulder development?
Mr FIGJAM
My 2 cents
Starting Strength, 5 x 5, 5-3-1 or 8-6-3
www.blackironbeast.com has some good programs.
Main lifts are Mil press, deads, bench and squats, you can do a basic workout which takes 20 minutes, lots of options with all the hard calcs done for you.
Im doing a 5-3-1 body building template which takes between 45 minutes and 1 hr dependant on rest time and lifts done.
The TRIUMVIRATE (smart mans program) should see you out of the gym in under 45 minutes
As for looks and strength you can have both with just lifting heavy on the basics with minimal assistance exercises, (i.e no bro curls or wrist curls or other stupid exercises that support the vain)
Bench will give you plenty of it
If you have to do a vertical shoulder exercise then I would say a bit of military press on the squats day.
But yes, aesthetically bench will develop them fine...and strength wise...well if you're trying to get a decent bench then bench is good for that :P
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
