Belts are great when used properly! I agree using them for every exercise is stupid! I use a belt for 1RM deadlift and squats only. I was taught by Nathan Baxter at a deadlift seminar how to actually use the belt properly and how to breathe into your belly, rather than into your chest. It's helpful as I'm also a lean build.
Wouldn't mind getting this tested as was thinking about giving it a go; has no carbs, no lactose and no fat.. Apparently the purest and most biologically available source of whey protein on the planet.
It comes in cherry vanilla, vanilla peanut butter and chocolate peanut butter flavours too... Nom nom
Bulk Nutrients is the go, IMO anyway, as it is way cheap and I like their product.
I only really go for WPC as it still has lots of other bits in it which are actually good for you, when they make it "pure" you lose a lot of the good stuff.
Actually all their products are cheap, why pay more for the same product, I save over 30% buying from them.
BN WPC
*chocolate, coffee, vanilla - all excellent
*banana, strawberry - good, but weak flavour
*mocha, cookies n cream, choc mint, pina colada - haven't tried
I just stick to vanilla and coffee myself now. Easiest to manipulate with other stuff like cocoa powder.
    • Hey looking for pointers or experiences with indicator wiring/ common faults for the blinkers on the r31, I have a 87 silhouette and am having dramas with the blinkers staying on (not flashing) to indicate right,while trying to indicate this way the relay makes a constant noise, The front passenger side fender blinker is missing the harness connector to the bulb so is not connected would this effect the opposite side? Both rears work as they should, and blinker that stays on functions normally when on hazards instead of indicating, have replaced all bulbs,fuses and relay Cheers
    • I’ll check the AFM’s and confirm. I’ve seen on another forum post years ago it’s identified with an orange sticker and larger diameter. Unsure if I can check the diameter without removing the air filter. Is there a way to identify if the AFM is stock? I’ve done a quick search and it looks like it might be a green sticker instead?   Will try check that turbo core tag. Looks like a very tight fit in there. Do you know what number would show if it was a stock T25 turbo?
    • The car and the 33GT-R wheels look great. I can't remember if spacers were needed for these but the offset looks perfect for the GTS25t.
    • And the lack of ubiquitous availability. If it was less likely that I'd run out of fuel while trying to cross the crime zone, I'd probably be all over it.
    • 98 dirty garbage, everything except fuel economy is better with e85
