Belts are great when used properly! I agree using them for every exercise is stupid! I use a belt for 1RM deadlift and squats only. I was taught by Nathan Baxter at a deadlift seminar how to actually use the belt properly and how to breathe into your belly, rather than into your chest. It's helpful as I'm also a lean build.
Wouldn't mind getting this tested as was thinking about giving it a go; has no carbs, no lactose and no fat.. Apparently the purest and most biologically available source of whey protein on the planet.
It comes in cherry vanilla, vanilla peanut butter and chocolate peanut butter flavours too... Nom nom
Bulk Nutrients is the go, IMO anyway, as it is way cheap and I like their product.
I only really go for WPC as it still has lots of other bits in it which are actually good for you, when they make it "pure" you lose a lot of the good stuff.
Actually all their products are cheap, why pay more for the same product, I save over 30% buying from them.
BN WPC
*chocolate, coffee, vanilla - all excellent
*banana, strawberry - good, but weak flavour
*mocha, cookies n cream, choc mint, pina colada - haven't tried
I just stick to vanilla and coffee myself now. Easiest to manipulate with other stuff like cocoa powder.
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
