Gym And Supplement Discussion
avrahan
My gym emailed me to say great news, we're doing 100k worth of upgrades for a nip and tuck. I opened it with excitement thinking here come the extra 5 and 10kg plates I've been waiting for (we have a severe shortage of these), along with some more oly bars for deadlifting and another squat rack.
100k of "functional equipment" upgrades. Being installed today and won't impact the free weights area. Farking cuuuunts. Do they know how much actually functional strength equipment that money could buy?!?
Down to the lightest i have been in years 88kg sitting 11-12% body fat strength starting to hit a wall but still pretty strong. Look flat and bloated from sups and bugger all carbs. Cant wait for another few weeks to switch things around a bit when i get below 10%bf
Joints are a bit sore so belts and straps for pretty much everything
Morning all.
I'm still here, doing little more than maintenance these days due to work, not great sleep, long winter season of illness etc. Lost 5-6kgs (not intentionally and it sucks, but hey, more abs) and am only getting 3x 30-40min sessions a week these days so unsurprisingly my strength/size has/is also going backwards.
Because I cannot easily control the factors affecting it, what's the best approach to try and minimise the losses? Drop the weight so I can get out the full rep/set scheme (3x8 in most cases, 2x15 on squats bu they are only light and are a special case due to my back) or continue doing what I've been doing which is struggle but keep adding sets to get the full volume out. as in 8, 8, 5, 3 or 8, 7, 6, 3 etc.
Good to see you guys (and Leesh) still cranking out your sessions :D
Make sure you calorie intake supports it, especially protein. Concentrate on your compounds with linear progression. 30-40mins should be plenty to get out your sets. If you've gotten weaker, reset, start again.
I'm taking a week off, will have a light session on Wednesday, upping food intake, trying to get to bed earlier, back on multivitamin, daily yoghurt/juice for better immune health etc.
Starting to feel slightly better, at least from the point of view of not catching anything for a few weeks.
That old man struggle is real - as Rev sits there laughing.
Thanks fellas. Yeah, the hips rising early is a bit of a common thing I do. I'm thinking it's related to not engaging my lats enough and thus not "drawing the bar back" quite enough.
Birds I'm 5'9 / 175cm or thereabouts. I think I've got slightly shorter limbs (femur in particular) and longer torso than average, which is supposedly common with my heritage.
I think I'm somewhere between the first and second images in the different types below.
  • Like 1
Must retract these comments
When they said the upgrades wouldn't affect the free weights area, it was a bit of a mistruth, as they have now created a second free weights area
Basically a huge crossfit/lifting/kettlebell station ala my previous gym
Complete with two deadlifting platforms, full size small plates and about 10 Ironedge squat and deadlift bars with some sweet, sweet knurling
f**k yeah
Every time Birds comes to my power lifting gym he has a sad about the bars though because they hurt his hands. I think they are awesome but maybe because I'm used to them. Once you go a texas bar you don't go back.
  • Like 2
    • I hadn't got that far, my main worry was the connection to the actual calipers themselves. I'm just using new (ish) stock brake lines in the stock setup. I've just had a stud welded to the knuckle that is a little lower than the original stud (so my knuckles have two studs each side) to not have it be stretched so far in previous BBK setups, so the "block" (in the second picture) mounts a little lower for me and I hope I don't need to change anything. I may have even changed the connection to the calipers in the past and have since forgotten I did that. I may not have. Guess how I'm gonna find out. Source: hopium
    • It's more so I'm using the 1x piece line from HEL that goes from the body to the caliper. There's no middle block/mount like the HFM ones or the GKtech ones. There are certain angles/suspension compression where the line actually slightly contacts the ARB. Below of how mine sit (not my photo): How I want it:
    • Oh I have mine all sitting in boxes ready to go, two sets of rotors, four sets of pads and caliper rebuild kits. They send a survey asking me if I had installed them months ago :p Grinder not necessary to fit the fronts, and not *really* for the rears. They have some good simple videos on how-to. I don't understand brake lines but from what I understand... somehow... OEM lines work, even though people say 350Z and 370Z use different banjo bolts, so it's possible 350'z had some different setup that Nissan changed to the 370Z/R33/R34 system? ....though are a little short, but past-me made a new bolt hole to bolt them to to reach my current fronts so I should be okay... maybe. In any case HFM don't sell any *different* line kits for R33/R34 front brakes than they do for the 370Z kits. So in my mind they must be compatible or they would have different products made to suit the different calipers. Please test and confirm for me kthx.
    • @Kinkstaah HFM will have a spicy BF sale in November, might be a good time to load up on the adaptors, new lines, etc. Then may the best grinder win lol.
    • I actually think the S15 is 80/20. I know I said 70/30 before but perhaps that is the GTT/GTST one. I wanna say it's the BM50 or BM44. I have one for sale if you want it GTSBoy, try your luck. For some reason the R34 GTT one is actually unlabelled, so it's a BM??????
