Yeah I know what you mean, it took 9 months of weekly, fortnightly then monthly physio to get my infraspinatus healed. I still need to be really careful or it comes back. A new physio gave me an exercise for my current injury which just flared up my infraspinatus a few weeks ago :(
Currently I have a back hyperextension that has been around for a month, and still quite painful.
Hang in there soldiers. My shoulder injury from nearly 2 years ago has made amazing improvements over the last 12 months. Still gives me very minor inflammation, but nothing distracting. And I thought the healing was as good as it would get after the first 6 months. I even smashed my old pre-injury PB on bench only a few months ago. Some shit just takes a long time to heal, but many of these injuries can be come back from provided good rest and rehabilitation, healing the injury around mobility movements etc.
4 specialists couldn't find anything visibly or physically wrong in spite of some pretty painful inflammation, so after 6 months I had resigned myself to it being a lifelong injury for me. Not so! The body can do amazing things overtime, things that science is yet to touch on :)
lol
Nah, out of the 4 specialists I saw, the osteopath made the most sense...he had the same opinion as the others, but a better explanation that I understood. He used a skeleton model to explain the joints and what my ultrasounds actually meant. Said there was nothing wrong with my mobility; the pain and feeling of something being wrong was nothing serious or else we would see it on ultrasound; it was something my body would have to heal over time (which is what osteos tend to subscribe to); I have, for lack of an actual medical term, clicky joint syndrome, where my joints are looser in their sockets than they should be and this likely caused my shoulder injury - means I have to be very careful with weights and technique. So on his advice I just kept at rehab, slowly introducing more mobility as I went along and slowly increasing the loads as well as icing it when it was inflamed, and these days I get hardly any, if any, inflammation after using the shoulder. Low reps don't bother it, but high reps can. I still don't have as much flexibility as my other arm, but as long as I can push weights I don't care.
Well for me I have hurt both shoulders on incline bench and press in the past.
One guy reckons my shoulders roll inwards and my back isnt engaging them and keeping them straight. He believes that is why my bench has always sucked.
What he doesn't know is why it hurts on the computer, sleeping, throwing a tennis ball and a number of other activities.
Bad posture is also to blame I think. Will see what physio thinks tomorrow
Hypermobility?
Nah doubt it, my joints aren't that flexible, they are just loose so to speak...could pop out or dislocate easy etc.
I have no doubts what my shoulder injury started out with was the supraspinatus getting caught between moving bones / joints.
good news about my physio, he thinks that it is all posture related and can be fixed pretty quick.
major thing that I have to do is change my desk lay out at home and work, sit up straighter, walk taller and a few simple back stretches.
also said i have scoliosis (if that is how it is spell it) which is why it hurts more on my right side rather then my left.
unfortunate thing is I have to lift less, especially anything above my head
Time to swap out the M for a B in your name now.
But seriously, good news that it's minor. I can second the posture comment as it made a lot of difference for me to stand up staight/walker taller/sit better etc. Oh and bent rows or something that involve shoulder girdle contraction (for me) as my shoulders were rolling forward from too much bench.
Anyone have tips to build some thickness in the upper pecs, primarily just below the collar bone? The rest of the pecs seem to be filling out nicely but the upper portion are making very slow progress in comparison. Currently do the following exercies for upper pecs:
- Incline dumbell (~30-degree angle)
- Incline barbell bench press (~30-degree angle)
- Incline flyes (sometimes cable, sometimes dumbells) (~30-degree angle)
Someone mentioned adjusting the bench angle to about 45-50 degrees, but I have always been under the pretense that the higher angle results in more deltoid activation?
Edited by T.D
genetics.
depending who you talk to will depend on the answer. Some people believe that there is a difference between the upper and lower pec, others claim its all the one pec
whatever u do just make sure you smash the chest area and eat enough food for it to recover
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
