I don't get why someone would need to jerk off once they are in a relationship where they see their partner every day, unless their partner is shit and doesn't meet their needs. Sex should be at least daily why jerk off?
Daily? f**k im lucky to get it monthly
The best thing about women getting older is that they get as toey as hell again from around 35, and by then they know how to use it.
FWIW, I'm 50 this year and the bird is 44.
Good times
  • Like 1
Good times
Looks like I won't be slowing down any time soon then...
Have you bred yet, usually after a woman breeds they slow down a bit, only for a while though, then its good to go till they have their next kid.
Though with some the plan of smashing kids out wins out over desire, this is the best plan of attack Ive seen if you want more than one and still have a life
Disclaimer: This is the view of a bloke, women may/will see it differently........like always, LOL..
I don't think anything would or could slow me down ha
School teacher?
If so, yeah, nothing like it, you don't get to hand your own back.
The thought of handing mine back comes on the odd occasion, In reality I couldn't live without them!
Tell me that after you have had a kid or two
Mmm nah, she won't slow down, or I seriously doubt she will. Like no other woman I've been with. Cannot keep up, not that my libido is all that high either; I'm comfortable with a few times a week. But I could wake her up from a deep slumber with the flu at some ungodly hour and she would be up for it.
This is probably why she's a decent lifter lol
  • Like 1
90kg is great work. Strong press actually.
Be good to get back to clean and press. I am stuck in rehab zone. Doing lame dumbbell presses and Cubans. Have wrist/forearm issues still. Likely need surgery to fix.
I have my eye on working up to 50kg a side if I have to live with them in the mean time.
I've never understood this.
The sensation of having your dick sucked would well and truly be overruled by the sensation of having a dick in your mouth.
If you numb your mouth, same same?
I'd say you have above average sex drive Leesh. Not even the keenest high school gf wanted it that much (I did back then) and you could look at her the right way and get her going so it was an easy sell.
Bottom line, I don't want dicks in my mouth. Mine or otherwise. Numb, drunk, super horny, doesn't matter.
I have no issue with the logic Birds is using or any trouble believing he would happily felate himself.
That's narcissist's for you ;)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
