I don't get why someone would need to jerk off once they are in a relationship where they see their partner every day, unless their partner is shit and doesn't meet their needs. Sex should be at least daily why jerk off?
Daily? f**k im lucky to get it monthly
The best thing about women getting older is that they get as toey as hell again from around 35, and by then they know how to use it.
FWIW, I'm 50 this year and the bird is 44.
Good times
  • Like 1
Good times
Looks like I won't be slowing down any time soon then...
Have you bred yet, usually after a woman breeds they slow down a bit, only for a while though, then its good to go till they have their next kid.
Though with some the plan of smashing kids out wins out over desire, this is the best plan of attack Ive seen if you want more than one and still have a life
Disclaimer: This is the view of a bloke, women may/will see it differently........like always, LOL..
I don't think anything would or could slow me down ha
School teacher?
If so, yeah, nothing like it, you don't get to hand your own back.
The thought of handing mine back comes on the odd occasion, In reality I couldn't live without them!
Tell me that after you have had a kid or two
Mmm nah, she won't slow down, or I seriously doubt she will. Like no other woman I've been with. Cannot keep up, not that my libido is all that high either; I'm comfortable with a few times a week. But I could wake her up from a deep slumber with the flu at some ungodly hour and she would be up for it.
This is probably why she's a decent lifter lol
  • Like 1
90kg is great work. Strong press actually.
Be good to get back to clean and press. I am stuck in rehab zone. Doing lame dumbbell presses and Cubans. Have wrist/forearm issues still. Likely need surgery to fix.
I have my eye on working up to 50kg a side if I have to live with them in the mean time.
I've never understood this.
The sensation of having your dick sucked would well and truly be overruled by the sensation of having a dick in your mouth.
If you numb your mouth, same same?
I'd say you have above average sex drive Leesh. Not even the keenest high school gf wanted it that much (I did back then) and you could look at her the right way and get her going so it was an easy sell.
Bottom line, I don't want dicks in my mouth. Mine or otherwise. Numb, drunk, super horny, doesn't matter.
I have no issue with the logic Birds is using or any trouble believing he would happily felate himself.
That's narcissist's for you ;)
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
