  • Replies 81
Great stuff, mines 04/06/08..
We'll have a 'family' class in 2028, father/kid combination...
I'll be in that, Lachy is already a motorhead at 3 1/2.
I have set a benchmark with babies for you all to aspire to, I delivered my daughter myself at home. :) She wanted out and I thought, how hard could this be, saw it done once so bah.
The Dr. didn't respond to my request for a partial refund on fees though. :cheers:
Motorsport 2008 begins!!!
Entry Form - http://www.wrx.com.au/motorsport/feb9wintonentry.pdf
Supp Regs - http://www.wrx.com.au/motorsport/feb9wintonsupregs.pdf
Entries will close for this event on the 2nd of February. Please note that there is a discount on the entry fees of $30 if we have received your entry and payment prior to the 26th of January (Australia Day!).
EDIT ***Entry list now up - http://www.wrx.com.au/forum/viewtopic.php?t=46710 - please make sure your entry is received.
Maybe i'm blind or something but does anyone have the bank details of the person we need to send our money to via Direct Deposit?
And let's say i enter this trackday stating that I'm driving a 34 gtt, but during this period I might changed my car to a gtr, is that possible to enter the club championships?
I'll take on the 2nd question. If you change cars half way through the season, then you can still accumulate point towrds the outright club champion, which will be a combination of all points scored throughout the season in any class you were in. But you can not get points in one class and carry these across to another class and win the class. Class points will only be valid in that class.
Hope that makes sense, Ta Chris.
Have enquired and was told it was overlooked when the entry form was made, but that you can pay by DD.
Will get the bank details for you and update the first post ASAP.
I have set a benchmark with babies for you all to aspire to, I delivered my daughter myself at home. :( She wanted out and I thought, how hard could this be, saw it done once so bah.
The Dr. didn't respond to my request for a partial refund on fees though. :)
Holy crap!!!! That's amazing...
I don't think I'd be able to that, I would have fired up the 'R' and gone through every red light...
There are a few problems with that... :(
- The first time you jammed on the big alcons the baby would come flying out.
- You'd have to warm up the engine first
- You'd get 'gunk' all over your interior
Congrats by the way Jack. Now Give me your car.
I too think you should give Ferni your car :)
Also - I got the direct deposit details (1st post updated)
BSB: 063 128
Account No: 1036 1099
In the Account To description, please put "Winton" followed by your surname.
There are a few problems with that... :D
hehehe, come to think about it your right...
The car is for sale...
:P:P
I too think you should give Ferni your car :ermm:
BSB: 063 128
What Account Name do we address that to Bec? LOL!!
Sorry to trouble you. :) I was about to make payment until i realize and account name is needed :P.
And do i still get the $30 discount?!?!?!?!?!!?!?! :( I was intending to pay them TODAY :P
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
