Hi Guys,
I think the subject says it all but does anybody know where to get new rocker cover gaskets for a RB25det engine other than Nissan themselves? I rang Brighton Nissan today as I've been dealing with the guy there for years and he really looks after me price wise... well I hope he has, and he said that I'll be looking at $30.00 per side, there's actually 2, one for each cam but what I forgot to ask him was how much for the bolt seals coz they will also need replacing... no doubt.
I'm not to sure if the gaskets will come with the bolt seals but I'm guessing not... not 100% sure though meaning that there's about 20 odd bolt seals probably worth $3- $4 dollars each? it starts getting a little expensive! What do you guys think?
Does anyone know where to get new ones any cheaper with the bolt seals? Hope I don't sound like to much of a tight ass!
Thanks,
Gianni
https://www.sau.com.au/forums/topic/20106-common-r33-rocker-cover-gasket-leak/
  • 1 month later...
I don't think $33 is too bad. Mine aren't leaking at all, so I would think generally speaking they last around 8 years or more. That beats the hell out of Commodore gaskets which are about $10 but leak straight out of the packet :D
I paid $26ea from Unley Nissan here in SA. I re-used the original bolt seals, no prob's so far.... if you ignore the fact that No:1 ringland cracked :D unrelated of course.
Make sure it is leaking before you go to the trouble of replacing them...
Quite common to spill oil down the intake side when topping the oil up and over time the spilt oil will progress towards the rear of the motor looking just like a leaky intake cam cover gasket...
Clean the oil off with a rag and some degreaser and see if the leak comes back... Mine didn't...
If it's the exhaust side though, probably rooted gasket...
Just my opinion tho...
  • 3 years later...
Anyone know what the part numbers are? Also, would the washer be important. I cant find a dealer where i live that has the washers in stock. they've got the belts though.
I'd be keen on the part numbers as well, my r33 started to leak a bit if i dont let the car warm up...can this be done easily at home?? just unscrew the bolts for the rocker covers and replace the seals etc??
my rocker covers are leaking aswell "aparently" the other workshop i was at changed them... cops ass!!!
how much for gen nissan rocker cover gaskets, i also need a gen nissan exhaust manifold gasket..
therepost-17300-1160253786.jpg you go
Those aren't the part numbers you need....the Nissan parts guy will probably just stare blankly at you. It's much better to have the full VIN of the car but here's what to do:
- double click on the empty box to the right of the one that says 'Part No'
- enter the first three numbers of the 'Part Code' shown in your list....in this case 132....and hit return
- FAST may throw up another box asking which model/year for the car (but rocker cover gaskets are pretty common across the range so perhaps not). If it does you'll have to select (click on) the relevent car/year line in the pop-up.
- the full PN's should now appear in the main window, along with some other info.
Hope that helps
Called Nissan Today:
Rocket Cover Gaskets..
Part No. 13270-58S01 (1x Each)
Part No. 13270-58S11 (1x Each)
Washers (Rubber)
Part No. 13268-58S01 (1x Set of 20 Seals)
Hope this helps. Rob
Screen dump for you :thumbsup:
Oh and the price was about $30 bucks or so think it was $36 but under $40 each. They should have them for me by the next day :thumbsup: also found the part number for the rubber seals it comes in a set of 20 which will set you back about $2.45 each a full set is about $49.50/
Is there much to replacing them??? just unscrew the rocket covers and replace the seals?? obviously in a clean environment so no contaminants get in.
Cheers Rob
    • Your chihuahuas look weird!
    • Call me the "Crazy Cat Man"...., maybe that should be my new forum name....LOL....., but seriously.....someone change it please, thanks Just grabbed the two black Oriental kittens that I ordered a few months ago to guard the house, I am assuming that because they are Orientals they know KungFu, Karate, or are Ninjas, or some other lethal fighting skill, even at only 3 months old they already have Parkour down pat Introducing...Bella & Donna
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
