Hi all,
My skyline has been up for sale, but its time for her to really go.
shes an R32 gtst Manual
1992
Blue with violet pearl
19" HP design rims with new rear tyres
Final Konnexion Bodykit
Front mount intercooler
K&N pod filter with heat sheild
Turbo smart Dual stage boost controller
Turbo back 3" exhaust with High flo cat
Turbo timer
Bosch 040 Fuel pump
High flo turbo (as ive been told) which runs 16psi all day every day
Whiteline Springs
Bilstein Shocks
Whiteline Adjustable heavy duty sway bars
Whiteline adujustable Camber and castor kits front and rear
Whiteline rear diff align bushes
front strut brace
Alpine stereo
front splits & rear 2ways
x2 fiberglassed in 12" alpine subs
Checkerplate floor
racing pedals
Impul gear knob
Autotechnica steering wheel
Autometer boost and airflow A pillar mounted guages
Full underbody LED mulit coloured light system
Timing belt done 12,000km ago
As well as new:
Radiator
Waterpump
iridium spark plugs
Clutch slave cylinder & master cylinder
Injector flush (good)
Serviced regularly and repaired by licenced mechanic
There is prob more, but cant think of at this time.
Beautiful car to drive.. qucik and fun.
Has to go.
Price drop $15,000
No joyriders, or waste of timers please..
Ph: 0402419988
or PM me..
Thanx
https://www.sau.com.au/forums/topic/201064-r32-gtst-for-sale/
Car? What car?
I'm with Mick: what car?
Seriously, sad to see another SAU'er putting their Skyline up for sale. What's in the pipeline, Andrew? Or would you rather keep it quiet? I personally hope it involves an RB26DETT...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
