Hi
I just started my RB26 for the first time after a rebuild, so i had to prime the pump and turbo core etc with engine oil.
I was just wondering if those with oil coolers actually dump the oil within the cooler and then prime the cooler with new oil when they change their engine oil.
The reason im asking is that i just installed an Earls 19 row (wide) oil cooler, and the fittings are facing downwards. So in order to prime the cooler (probably about 1.5 litres with lines), its a massive pain in the arse, and requires removal of the braided lines etc etc.
I must have spent over 20 grand on the engine, so if i have to do it every 5000kms to avoid engine wear then so be it, but i was just wondering if i remove the old oil from the cooler, then prime the oil filter (and obviously engine) with new stuff, will the lack of oil in the cooler for a few seconds be damaging to the engine?
Its hard to explain, but hopefully you guys in the know will get what im talking about.
For those that are interested, the engine started no worries, and got oil pressure straight away. It started off the key with the Autronic SM4 and sounds great. This thing has been in build for about 4 years (after some bad luck and engine failures), so i was pretty nervous about something going wrong.
Anyway, ill include some pics of the cooler and the remote oil filter so you know what i mean. Sorry about the big files though.
Shaun.
I have a very similar setup only the oil filter is down low.... tried to prime the cooler but could only get a bit under 500ml in there with everything connected (feeding using funnel into dash10 braid not fun). I'm thinking crank it for a few seconds (no fuel) till I get oil pressure then start it normally. Im fairly sure the oil filter being so low self primes on mine though, well it filled with oil when I filled the sump anyway. Yet to start it though, waiting on ecu (also an sm4).
btw your engine looks very similar to mine :P
Edited by DCIEVE
Yeah, i disconnected the injectors and cranked it for aaaages, but i discovered you cant get oil pressure off the starter motor.
I was thinking of getting a mechanical pump (like a holley blue or something) with dash 10 fittings and connecting it to a battery so i can pump oil straight from the bottle into the cooler. Might be a bit of an overkill though.
I love the SM4. Where/how are you mounting yours?
Im just in the process of mounting mine in the factory position, but im finding it really hard to make it look stock! The worst thing i ever did was take my car out of rego! Now ive gotta try to convince the engineer that the computer is standard so that i dont have to get emissions tested.
Shaun.
interesting point.
I never primed the cooler on my 180 and if you hadnt started it for ages then sometimes you would get a little rattle from the timing chain when it lost oil for that fraction as the cooler/lines etc filled up. And like you said there is that small volume of oil still in there you cannot get out when you change the oil.
If you crank the motor you wont get oil pressure no, but it will pump some around, there a postive displacement so the oil has to go some where.
Im interested to know what anyone recomends on this as i want to put an oil cooler on my stagea and i dont wana kill a expensive motor either.
interesting point.
its hard to think how u would get every little bit of dirty oil out of the cooler isnt it cuz it would be silly to have like a litre of shitty oil in the cooler that goes into the sump and mixes with fresh new oil hmmmm how could we get around this
you disconnect the bottom fitting on the cooler and drain it separately :) not exactly rocket science.
I have been advised by certain knowledgeable people that oil coolers should be mounted on their side with the inlet at the bottom and the outlet on the top to avoid an air pocket within the core. Makes sense if you think about it simply, but in practice will the core fill if mounted like shaun's? Mines mounted the same way btw, except compared to shauns extruded brackets mine may as well be held in with fencing wire and duct tape :rolleyes:
the easier way, yet more expensive way, is to drain the oil, then fill it up with new oil, then run it up to temp... then drain this again. you could also use engine flush with the new oil that you have put in before the draining.
then once its all drained, put your good oil in it and away you go. that way all the old oil sitting in the cooler is going to be flushed out from the previous drain.
hell of a lot less messier :rolleyes:
Yeah, getting the old oil out of the cooler is easy, as mentioned above. There would still be some left in the lines, but i dont think it would be significant when filled up with 7 litres of new stuff.
The issue is getting new stuff to the cooler. Now you mention it, the way mine is mounted, it wouldnt just go in the bottom of the cooler and straight out the other side without permiating through the whole core would it? Hope not. Surely there would be enough pressure there to create a 'backlog' of oil in the cooler that would permiate through the rest of it, and they told me that it didnt matter which way it was mounted.
When i felt the cooler, it was all pretty hot.
Oh, im pretty obsessive conpulsive with mounting things and oil issues.
Shaun.
Edited by Shaun
some taxi's do - but i was getting at the lack of cold start conditions as their key to long engine life
from what my mate told me (he did a fair bit of research), a lot of truck/logistic companies use them as standard on their trucks
on his 300zx, when he turns on to accessories he sees oil pressure. that's before he turns to start the engine. it doesn't get much better than that.
if i were to do any kind of rebuild i would definately consider this, especially if my engine is worth more than my car (as in your case)
Edited by WazR32GTSt
I thought i had an obsessive compulsive issue, the 10's of hours iv spent stressing over oil and fuel lines. Setup, maintenance, long term effects etc :P
Good to see im not the only one LoL
Yeah, im definately OCD. I mop my garage floor more than those in my house.
Shaun.
Rofl, i cut specifically shaped pieces of foam and fit them, every time i remove i.manifold, e.manifold, power steering lines etc etc. I comb my carpet and wax the bottom of my feet!
ok, i made those last two up for affect.
But seriousally, with all the dough you pour into a car, to think a fuel / oil issue could kill your motor dead quick, pains me, hence the thought out modifications :P
Yeah, i think ill just prime the oil filter and then unplug the injectors and crank it over for a while. I wont see oil pressure bit at least it wil circulated oil around a bit.
Shaun
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
