where are u located?
how big do u want? and how many? :D
hey andz,
im located in pooraka, but i'll come grab them as long as its not too far
as many as i can get, maybe 10 or so max, fairly big size, something that would still fit in the back of a wagon though.
i appreciate the help andz :(
Edited by AFTDRK
https://www.sau.com.au/forums/topic/201159-empty-boxes/#findComment-3577098
Big isnt always better. (not that i've had any complaints, and the girls all walk away happy (bow legged, but happy) LOL)
I often use fruit boxes (banannas and the like) for books and paperwork as they are very strong, stack well, and are manageable. Big boxes often get too heavy and are prone to tearing open unless the stuff you are packing is light.
https://www.sau.com.au/forums/topic/201159-empty-boxes/#findComment-3577127
:laughing-smiley-014: thanks, i'll keep that in mind
https://www.sau.com.au/forums/topic/201159-empty-boxes/#findComment-3577136
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
