hey man dont bag vl's they r a pov mans skyline ahahahahahaah! it took me 1 month to put an rb20 in mine and the rest!!, custom exaust custom intercooler.(i was little back then) lets hope that vl_bogandude comment wasnt at my expense! lol but yet no one is answering my question! i know a alot of technical here and there's and never heard of this so called turbo dose???!?!?!?!! WTF
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578047
rite the smart arse comments were not need if u want me to use the correct wording ill say compressor surge i just thought id say dose cuz all u hard kunts normally go omg bro sick dose from da skyline der bro....
f**k.
rite... no blow off valves we all know the noise sum ppl call it flutter call it wat u like but they always say its pretty much the compressor wheel trying to pull itself through the front cover everything u hear this noise... i hope ive made it clear wat im talking about now....
sum decent replies to wat ppl think on this subject would b handy....
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578064
a "dose" pipe as the vl community refer to it.. is just a solid intake pipe.. cause majority of them run no bov's when they do this there "flutter" gets a shitload loader.. hence why they refer to it as "dosing" or "dose pipe" n stupid shit.
ahhh many thanks...... hmmm since i was about 4 i knew that plumb back was the only way to live so no wonder ive never heard of this so called "turbo dose" heheheh p.s. only turbo engines ive ever had are rb20 and rb26dett........ never thought twice about haveing a atmospheric bov...... prefer recycling my air and reducing lag personally!
peace and thanks for clearing up this unheard of topic :D
turbo dose= turbo pain
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578068
f**k.
think about the questions before you ask it than
yes it is bad for your comp wheel.. think about it.. that wheel is spinning f**king fast and its pushing air one way.. that noise you here is air chopping thru the blades tryin to get back out the intake pipe now thinking of it like that.. do you think its good or bad?
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578075
reversion is bad!
reversion = kill turbo :(
does sound pretty cool though
don't worry skylinekid there's still love!!!
c'mon group hug :P
lol riteeeee......
dahh yeh riteo i just hear ppl with surge all the time... gahhh y cant it be good it sounds f**kin awsome lol wank factor pretty much
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578106
skyline kid what u drive?
r33 gtst. in process of building motor have got three options.... rb25 block gtr crank h beam eagle rods je pistons fully built head...
rb26 transplant same as listed for rb25 but with the flow characteristics of a 26 head with cams and so forth.
or a 26/30 built bottom head with cams blah blah you catch my drift i just cant make up my mind and i cant find ne decent machinist that dont want my left nut for making the 26/30 combo or doing machine work i was for both rb25 /26 engines
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578122
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
