hey man dont bag vl's they r a pov mans skyline ahahahahahaah! it took me 1 month to put an rb20 in mine and the rest!!, custom exaust custom intercooler.(i was little back then) lets hope that vl_bogandude comment wasnt at my expense! lol but yet no one is answering my question! i know a alot of technical here and there's and never heard of this so called turbo dose???!?!?!?!! WTF
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578047
rite the smart arse comments were not need if u want me to use the correct wording ill say compressor surge i just thought id say dose cuz all u hard kunts normally go omg bro sick dose from da skyline der bro....
f**k.
rite... no blow off valves we all know the noise sum ppl call it flutter call it wat u like but they always say its pretty much the compressor wheel trying to pull itself through the front cover everything u hear this noise... i hope ive made it clear wat im talking about now....
sum decent replies to wat ppl think on this subject would b handy....
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578064
a "dose" pipe as the vl community refer to it.. is just a solid intake pipe.. cause majority of them run no bov's when they do this there "flutter" gets a shitload loader.. hence why they refer to it as "dosing" or "dose pipe" n stupid shit.
ahhh many thanks...... hmmm since i was about 4 i knew that plumb back was the only way to live so no wonder ive never heard of this so called "turbo dose" heheheh p.s. only turbo engines ive ever had are rb20 and rb26dett........ never thought twice about haveing a atmospheric bov...... prefer recycling my air and reducing lag personally!
peace and thanks for clearing up this unheard of topic :D
turbo dose= turbo pain
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578068
f**k.
think about the questions before you ask it than
yes it is bad for your comp wheel.. think about it.. that wheel is spinning f**king fast and its pushing air one way.. that noise you here is air chopping thru the blades tryin to get back out the intake pipe now thinking of it like that.. do you think its good or bad?
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578075
reversion is bad!
reversion = kill turbo :(
does sound pretty cool though
don't worry skylinekid there's still love!!!
c'mon group hug :P
lol riteeeee......
dahh yeh riteo i just hear ppl with surge all the time... gahhh y cant it be good it sounds f**kin awsome lol wank factor pretty much
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578106
skyline kid what u drive?
r33 gtst. in process of building motor have got three options.... rb25 block gtr crank h beam eagle rods je pistons fully built head...
rb26 transplant same as listed for rb25 but with the flow characteristics of a 26 head with cams and so forth.
or a 26/30 built bottom head with cams blah blah you catch my drift i just cant make up my mind and i cant find ne decent machinist that dont want my left nut for making the 26/30 combo or doing machine work i was for both rb25 /26 engines
https://www.sau.com.au/forums/topic/201242-turbo-dose/#findComment-3578122
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
