My car is a 32 gtr...I have the stock intercooler still and have added apexi pod filters
But for some reason i'm not sure if the cooler is working effectively or not.
The reason I ask is because I cannot hear much spooling.
Is there a way of checking if the cooler is working right or get it cleaned or something...
Cheers
https://www.sau.com.au/forums/topic/201323-intercooler/
Ha - vote #1 best question of "08!!
A IC is a glorified radiator, used to move temp energy out of a less viscous medium... intake charge air.
Gets some thermo couples and stick em pre and post IC to check yours is working ok.
I can assure you, it has no effect on spool noise
Edited by GeeTR
https://www.sau.com.au/forums/topic/201323-intercooler/#findComment-3579012
go for a drive, fairly spirited. Then jump out and put a hand on each end tank. If your inlet side is a whole bunch colder than your turbo side, its working. As long as youre not loosing boost pressure, its fine.
https://www.sau.com.au/forums/topic/201323-intercooler/#findComment-3579023
Doesn't do that for me on my GTT R34 side mount, its bloody hot on both sides...wats the go? mines broken aye?
https://www.sau.com.au/forums/topic/201323-intercooler/#findComment-3579112
probly,as i have done the same experiment on my car several times and can feel the difference dramaticly.
r32 with 34smic.
https://www.sau.com.au/forums/topic/201323-intercooler/#findComment-3579137
youll probably find the issue with the SMIC is its location, not the core itself
if you can setup some good ducting to force air into the car (not just the hope for the best strategy) it might work better and drop temperature more
https://www.sau.com.au/forums/topic/201323-intercooler/#findComment-3579147
or even better if ur lucky enough to have one of those laser pointed surface temperature readers that would b handy to get an actual degree difference from the 2 end tanks
https://www.sau.com.au/forums/topic/201323-intercooler/#findComment-3579727
Thanks for your responses...
I;m actually not fussed about the spoooling noise....I just assumed that that noise was being
generated through the air intake. And seeing as though I could not hear much I was worried that
the cooler was not working optimally...
The reason I was under the assumption that the spooling noise was generated from the cooler
is because it sounds like air being sucked in....so apologies for my silly asssumption.
cheers.
https://www.sau.com.au/forums/topic/201323-intercooler/#findComment-3580553
That is the induction noise going through your pod (yes air being sucked in) (noise is created by the restriction of filter, adding the two will half the restriction of the intake and thus noise)
There are heaps of ways to measure the efficiency of your cooler, start by measuring inlet and outlet temperatures as discussed above using a thermocouple or a pyrometer (that laser thingy:)
1 - (%final - initial)/initial = cooler efficiency
And yes they can be cleaned, do a search on here but im assuming you just pour some particular type of evaporative alcohol inside, swirl and poor out i.e. kero (heaps of black road grime should come out)
Actually if you think about it, the denser air charge (long story short) will cause the turbo to spin faster, air is inducted through the impellor at a faster rate so the pitch will change
Edited by Jmaac
https://www.sau.com.au/forums/topic/201323-intercooler/#findComment-3580996
Clean the intercooler with carbie cleaner.
I did it to an R33 smic and got an extra 2psi. I was surprised.
Removing and cleaning the cooler is extra necessary if you haven't got a catch can- oil buildup inside the cooler reduces it's ability to transfer heat from the charge.
Get the gloves out!
https://www.sau.com.au/forums/topic/201323-intercooler/#findComment-3581022
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
