  • Replies 176
off topic but it was on channel 10 lol: I just saw on Channel 10 about some apprentice who got threatened in his s13 by 2 guys with machetes... the guys took the car... and set it on fire..
How screwed in the head can ppl get. :S
Edited by Magic
f*kn idiots, they cant even get the specs of a car right - how the hell do people believe all the bullshit they hear on the news when the make mistakes as basic as that...
The car does look awesome though, thanks for the upload :D
And i have never seen 12 people viewing the one post at once lol!
Yeah it was in Perth and his s13 wasn't insured either. =\
The driver was fine, they stole the car and judging on the footage they set it on fire in a vacant lot.
I mean wtf would drive someone to hijack a car... then burn it. :D
Edited by Magic
good thing is that it apparently then has been allowed to run in targa west
couple of us were discussing it at MV on the weekend - at first i think it wasnt allowed
mind you the 180km/h gps speedcut would suck ass....
So this unveiling of the gtr tonight, does anyone know its open to all? Or is it only for a select few who got to RSVP?
It's invite only, so if you didn't get an invite I wouldn't bother turning up.
I'm sure it will be on display at there showrooms soon enough for public viewing.
I heard that Nissan have refused to turn off the speedlimiter.
As it is based on GPS could be hard to bypass.
Anyone else heard this?
mines VX rom has already solve that problem :)
also rumour has it that alot of other brands have an ecu option for the r35 gtr already
Edited by [Michael]
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
