Dave Stone called me today and asked me to confirm how many people I have ready to attend the next drive day on the Thursday 8th Aug.
As a recap:
All day $130 if we can get 15 or more.
Morning or Arvo $90.
Non flammable head to toe, full-face helmet.
Passengers and spectators free.
Unregistered cars get looked at every closely but no eng docs required, I think? This is not a race event but safety is upmost.
I need to know if you are in and if you want a FULL DAY, MORNING or AFTERNOON.
Im a really busy at work and I cannot afford the Tue & Wed for the Cams Licence at Oran and then another day at the creek on Thursday. So I will be looking for someone to run the day. Bonks, can you put your hand up?
The names so far, from the expression of interest post.
Bonks
Dflash
Dazsta
Evil
Xrsist
+ friend
+ friend
Akira
Silver Arrow
+ Many Friends?
Majanal
Zane
Kabab
Peak RPM
Prank
Roy
Fatz
Julian GTS
RD20Sil
Beavis
Please all let me know.
P.S. I have my GTR back and she feels strong, just need to fix the oil leak on turbo #1.
https://www.sau.com.au/forums/topic/2015-syd-ec-drive-day-8802/
  • Replies 80
Yes Oz I will be going for the full day and will be happy to look after the group. So far from both Skyline forums I have the following names of those who have confirmed.
Full Day
Silver-Arrows + 4 (he never misses a track day anywhere)
Julian GTS-t
Roy
XrSiSt + 2
Bonks
Zane
Majanal + 1
Total = 14
Scratchings
Dflash
Prank
Peak RPM
Evil_weevil
Kabab
Still no word from:
Dazsta
Akira
Roy
Fatz
RD20Sil
Beavis
Come on people we are still a few short.
All I have just spoken to Moto Concepts.
We currently have 14 people and we have 15 spots allocated, Dave has said that we could push up to 20 if needed. Anyone else interested should get in quick!
Oz, Bonks,
Myself plus one mate are now a definate... think that maks 16... roll on baby... been waiting for a trackday for a long long time!!!
My have an extra but not sure yet.
Less than one week to go... Fatz what is your prob... the GTR not got the power you were hoping for?
Cheers,
Dan.
mmm power just trying to nistal a blitz dsbc .... does anyone know how to work it i dont know how to set the boost lever.. there is only two buttons cant be that hard furk
yea should be there but merli wants me to take his cams day spot on teu and wens and that cost alot but we will c
also i still own tracy 120 buck from last time furk
pete
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
