got my new car on saturday and im loving it :P
its a r32 gtst with a rb25 det with a hks gt-rs turbo, microtech ltx12 computer, custom intercooler and piping, a few other little bit runing around 14 pound boost
on standard then around 18 with the boost controller on
it has around 300 horses at the rears will get it dyno'd soon to confirm.
so heres some pics
hope you like
cheers
cameron
https://www.sau.com.au/forums/topic/201827-my-new-car/
  • Replies 41
Posted Images
that doesn't add up.
would have though alot more power than 220rwkw with the above.
I thought "That" turbo with "That" boost level (and supporting tuning and fuel mods) would produce over 250rwkw easily.
Edit - congrats on new car.
Edited by GTST
https://www.sau.com.au/forums/topic/201827-my-new-car/#findComment-3586834
thats what i thought but the guy i bought it off said around 300 horses at the wheels so at the moment i have to go with that until i get the dyno done which should be in about 2 weeks time so ill put the real amount on there then
https://www.sau.com.au/forums/topic/201827-my-new-car/#findComment-3587030
nice looking car mate!!!
i am doing the same but different, if you know what i mean.....
Want some r32 GTR rims? look smick on gtst's.
nar im ok for mags at the moment ill think about some 18s or somwthing later on
tell us when you do the stuff to your car and what power you make
cheers
https://www.sau.com.au/forums/topic/201827-my-new-car/#findComment-3587756
cheers
lol ok just thought i'd ask.
well i am nearly finished actually so i hope to be driving it soon.
rb25det
rb25 box
and yeah etc etc.
should be making 200ish hp on starting tune, then double that after.
im liking the black on black. no chrome ruining it. good mods too. nice score mate :huh:
+ 1 for no chrome.
https://www.sau.com.au/forums/topic/201827-my-new-car/#findComment-3588677
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
