did you get scratches out with that Nick?
Light scratches & scuffs came out using plastx and a buff pad on my drill, most will require sandpaper though.
note this guide:
http://www.meguiarsonline.com/forums/showthread.php?t=20994
I had trouble finding paper above 2000 grit at bunnings & stratco, haven't tried searching again since.
i have scratches from sandpaper on my headlights, and am thinking about removing my eyelids. might give it a try soon
iirc it's about 24 bucks a bottle, try to find a foam applicator pad attachment for a drill as it is easier to work with than a standard "bonnet buff pad" which tend to break apart easier, I tried doing it by hand but took ages and came out no where near as good.
Anyone know of an Adelaide store to get 2500 & 3000 grit wet sand paper? Bunnings etc finish up around 2000 grit which is way too course.
+1
I have some scratches and crap on my lights. I had to take my eyelids of for regency. Wasnt pretty afterward. I would keep the lids on Damo. Depending what you used to put them on
Maybe Supercheap Auto, if not best bet would be a Auto Paint Dealer....such as Lonsdale Auto Paints (if you are south), maybe try your local crash repairers, they may sell you some.
  • 6 years later...
Hey guys, I know this thread is old but still relevant...I found the perfect combo to hit these filthy old lights to turn them to newish looking condition so here's my experience:
1) Wash them with water and soup and rubber with some force using a sponge. Let them dry off completely (important).
2) Get a fiber cloth and put some toothpaste on the lights and rub clockwise going from left to right, right to left directions.
3) Using just water - clean off the toothpaste and let it dry.
4) Buy a bottle of Autosol Metal Cleaner and wipe with a new clean fiber cloth and rub clockwise going from left to right, right to left directions. Repeat 2-3 times.
5) Using a hairdryer - heat up the headlights to let the Autosol cream lock in. I know this sounds weird but worked a treat for me. After like 2 minutes they look 200% better.
They usually start going yellowy again after a couple of months so repeat the above process again.
Good luck.
  • Like 1
+1 that's what I've been using.
I suggest use my method - this looks good but actually leaves a lights looking foggy and not crystal clear and only lasts a couple of weeks in the sun. My method will give you a couple of months.
I read that also. I had chicken soup but it turned the lights yellow. I then tried tomato soup and they went red. Good for brake lights i guess.
Toothpaste works well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
