I found this photo whilst searching on a Japanese site.
The japlish to go with it...
"Designed to be symmetrical with the main engine. Toward the bottom left is the air-cooled oil cooler. Rainer scrap iron, aluminum is employed by the boa.
Edited by nick33gtr
https://www.sau.com.au/forums/topic/201934-r35-gtr-engine-photograph/
That's looks crazy.
Anyone know why they used two intercoolers, rather than one large one (thus giving it a larger surface area)?
Because it makes the plumbing simpler & the cooling from the intercoolers is the same for each bank of the motor.
Notice the interccolers are mounted sideways....
^^^ yep what he said ----- remember, simple piping is also a key factor in efficient cooling.
looks like it would be a bitch to change the alternator in the car!
hopefully it's not to bad from under neath,
Just like any gtr a bitch to work on that said everything looks tight to work on and around at least its not as bad as 300zx engine out to change the filter lol
yeah oil cooler on the left.
only thing i find interesting, is that you'd think that having the intercoolers like that would slow the intake air speed down a bit compared to a fmic type cooler, as the air travels into the cooler then has to do 2 90 degree turns before it exits.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
