Looks like it was a great day.
It was a fantastic day... You don't know what you missed out on.
Did anyone get any photos of the pit girls? Or were you all too mesmerised by those skimpy outfits?
  • Replies 237
I can't read the white board and there looks like some people hadn't run.
Could someone type the results out with everyone included.
couple of late scratchings, and the pic wasn't taken at the end of the day, I think Donnan has a list of the final figures.
Top day guys, I thoroughly enjoyed it. Glen and Daniel did a great job running up the cars. Thanks to all who organised it and for having me along. :(
Hi Max, It was good to meet you. That engine bay looks tops. Welcome to the forum :(
Sorry guys, my name was down for the day but unfortunatly i was unable to go at the last minute.
Looks like that day was a success. Big KW numbers aswell.
same, (late) apologies for not showing, found out late on fri that had to work a full day on sat and couldnt get on here to pull out earlier
looks like it was a great day tho! Good stuff guys!
Once again, thank you very much to all those who attended, organised, took photos, made jokes, cooked and anyone who generally made the day a success!
Obviously the day went so well because of the work of Cejay and the boys at ESP, so they should receive the loudest cheers.
Anyways, without any further procrastination here are the results:
(if there is anyone who does not want their results up here, just PM me and i'll take you off)
31:
WhiteRB25DET 153
32GTS-T:
Bullet32 236
Ladybytes 152
ZCR 142
33GTS-T:
33Sedan 165
Tarmac 179
Towlie 164
Trident 292
32GTS-4:
CeJay 162
32GTR:
Donnan 238
Stunnd 214
Phatass 657crazy!
33GTR:
GZR33 421
Misc:
Nick's VL Turbo 286
Mad Max's F6 Typhoon 416
John's MkII Tourer 197
Nico's Supra 320
But none of these could stand the mighty power of Pat's Starlet of mass destruction with it's truly world defeating 54 front wheel kilowatts!
Hi Max, It was good to meet you. That engine bay looks tops. Welcome to the forum :domokun:
Thanks Tarmac. There were plenty of nice cars at the dyno day, and a bunch of nice people to go with it. As you can tell I'm a bit of a Skyline fan, so I'll certainly be checking out the forum from now on to see what other events are on. Cheers, Max.
HAHAHAHAHAHAHAHAHAHA...... :laughing-smiley-014: HAHAHAHA.... :D:P
Cheers for the laughs Donnan
Nice power too Max, pity I arrived too late to see your run. Phatass was awesome, and I really liked the way GZR33 spooled up, sounded very tough.
Sorry bout the late comment was waiting for the power figures etc then I was away working, just got back.
Will hopefully have my engine in and run in by the next event/dyno day. It was a good turn out and the weather was great all the cars there looked pretty good.
I rocked up a bit late that morining (Frikin' got called into work for a bit). Spewin' i missed the Phatass run on the dyno must have sounded wicked? Is there any video footage of the day?
  • 2 months later...
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
