ok guys i couldnt figure out which one was better,thermo's were up a point and then another post bought em back down and so fourth......so i changed the fan with the same type(well r33) and thermostat/bled system etc,maybe thermos down the track though,my next cooling upgrade will just be ali rad.....thanks for all the posts
SHAYNO
  • 3 weeks later...
  • Replies 44
Just an update on this - I installed a new alternator using the helpful alternator guide on these forums, and removed one of the SPAL fans, and replaced it with a lower rated (and less amp drawage) thermo from Repco. My RB25 180Sx is still giving me 80 degrees water temp and the alternator is running at 14.1 at startup and goes to 13.8 with the fans on.
Due to this I now have the SPAL fan I removed for sale if anyone is having cooling problems (check my signature), this fan with a regular/slimline pusher should fix your overheating problems.
Cheers.
  • 4 weeks later...
a warning for all:
as part of the fan controller setup i had to run the temp up to around 90 degrees (measured on the ECU coolant sensor), but i noticed the dash temp gauge (which uses a different sensor, single spade wire) had not moved past normal, around 80 degrees. So no matter how hot I ran it, the gauge wouldnt move past normal, little bit dangerous. Took sensor out and confirmed it with a bench test, in boiling water, resistance still showed ~80 degrees. Something that most people wouldnt think of replacing.
Im in Adelaide - dry heat.
Why would I need a thermo fan setup, over a larger Radiator?
radiator busted prexmas, got a (25-33%) larger Koyo item with an APC 1.3bar pressure cap
temps are down by 1 to 2 bars on the dash guage, sits a smidgen above halfway
Ive had the radiator boiling (water pump issue, now replaced, again) after some heated midnight Hills runs
My first Stagea was a non turbo neo engine - got really hot on a hot day with the airconditioner running. Replaced the stock 16mm radiator with a new 25mm for NZ$300 incl labour and no more overheating problems.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
