So i took my r32gtr down today to get a power fc and boost controller installed and tuned. Mods are full exhaust, hks intakes, splitfire coil packs, adj cam gears and thats pretty much it. Now the power/power fc boost controller is installed and the car is put up ontop the dyno. The cars put into gear and the clutch is let out and the car stars to accelerate but rear wheels are being help back by something so the torque is sent thru to the front wheels while the back wheels are being help back, almost as if the rear brakes are being applied.
So what they did was stop the car and run it in RWD mode by flicking the switch i have rigged up to the fuse under the dash. The car does the same thing but now without transferring any torque to the front wheels as the switch is flicked over 2 RWD mode. So its as if the brakes are being applied when any speed is gained.
Next what they did was replace the stock ecu which also had the same result in both RWD and 4WD modes.
So they decided to take the car for a spin around the block to see if the same thing happens. The result was the car driving perfectly fine in 4wd mode (Torque was being applied to the front as usual) and also in RWD mode(No front torque transferred).
Now heres the weird part. When the brakes on the dyno are turned off(load is applied to the rollers by a brake to measure the power output of the car like you all know a dyno does) the car drives fine and can accelerate normally.
So just in summary the problem is I cant get the power FC tuned because the rear wheels are being help back by something when you try to accelerate on the dyno in both RWD and 4WD modes. When the car is put back on the road it drives normally in both RWD and 4WD modes with both ecu's in.
Could it possibly be a fault in the dyno brakes? I cant think of anything else that it might be.
The workshop owner has never seen anything like this he said and neither have I ? Any help or idea's would be great.
https://www.sau.com.au/forums/topic/202549-weird-r32gtrdyno-problem/
I'm not 100% of your issue. But keep in mind when you go to 2WD, you generally pull a relay which controls both ATTESSA and ABS. If you have hooked up your switch incorrectly, then its turning ATTESSA off only.... resulting in the ABS kicking in when the rear turn and the front don't...
Could this be your issue? :D:blink:
As a test, switch to 2WD and then on the street, induce some wheelspin. If the ABS kicks in, my suggesiton is correct.
Edited by GeeTR
thanks for the replys. Im pretty sure its hooked up right as when i switch to 2wd mode and induce some wheelspin on the street the abs doesnt kick in. I have one of those garage switches off the forums here. Also the anti-lock light comes on with the 4wd light when the switch is flicked.
The guy said other cars are on the dyno are fine. But he did just give me a call and said he talked to his friend who had the same problem and he did reset something. So im taking it down now and ill see how i go.
cheers
All was sorted. He reset something on the dyno, I'm not sure what it was and then it worked fine after that :(
I managed 244 kw at 1 bar. Car is stock apart from full exhaust, hks intakes, splitfire coil packs, adj cam gears and an exedy clutch. I'm pretty happy with the result. I'm also hitting Calder park this Friday to see what 1/4 mile time i can get. I'll try and post the dyno sheet up to see what you guys think about the graph. Cheers
your killin me lol i got similar mods and only made 200 awkw and 625 nm of torque. how much torque u make?? and can anyone tell my why i only made 200?? car is in awesome condition and running high boost of 1 bar
Edited by jenkies
Could this be your issue? :(:)
that's unpossible. :P ABS releases brake pressure when you lock wheels under braking. it doesn't apply the brakes all by itself.
also, the cabin fuse is the ABS sensor fuse so it cannot just disable ABS, or just ATTESA. there is a fuse in the engine bay that can independently disable ATTESA but leave ABS alone but most people are too lazy to go for that one and just use the cabin one.
anyway, problems solved - faulty dyno. :rofl:
Mate if your bloke doesnt know how to setup his dyno I wouldnt let him any where near a PFC.
PFC isnt just plug and play you really need to know what your doing. A PFC can be the best modd to blow up your motor the quickest, youl need "help back" to another workshop.
can i ask where you took it to?
I'm pretty sure he knows what he's doing. He tunes cars all around the world i was told by some other people. And the car is running perfect atm so im very happy with the work. His name is Ray and the shop is now called ART in heidelberg.
that's unpossible. :( ABS releases brake pressure when you lock wheels under braking. it doesn't apply the brakes all by itself.
anyway, problems solved - faulty dyno. :)
Hah - v.good point bout release not apply! ma baddness :P
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
