Had a couple quotes for an exhaust for my GTR 33.
Full exhaust, dump pipes, high flow cat etc etc
All around $2000+
That a bit steep????
Anyone recommend any where to go?
And also whats the best size exhaust to go for?? Performance wise?
Cheers
https://www.sau.com.au/forums/topic/202758-exhaust-places/
  • Replies 42
Exhaust Technology on goodwood road, near the underpass are great.
i have had some small fixes etc done by D&T in the city cos its close to my work, but if it goes on the books, and not a cash sale expect to part with a fair few $$
https://www.sau.com.au/forums/topic/202758-exhaust-places/#findComment-3598054
give them a call and find out prices i guess.
when i was calling up trying to find prices for my extractors, Exhaust Tech were the only ones with the best price, best service and the ones that didnt want my car for nearly 2 weeks :(
Exhaust Tech only needed her for a day and a half and the extractors cost 680 made and fitted, while every else wanted 1200+ plus.
https://www.sau.com.au/forums/topic/202758-exhaust-places/#findComment-3598066
AAA Exhausts, system for GTS-T was $1300 cash so id imagine GTR to be only few hundred extra. Top notch work & they generally use the magnaflow stuff which gives a nice deep sound without making too much noise.
https://www.sau.com.au/forums/topic/202758-exhaust-places/#findComment-3598130
The bigger the exhaust the more noise you will make!!!!
Three inch is big enough, but you can run up to 4 inch piping if you want.
Please remember that you have two dumps and this is where alot of the cost is as well as the type of cat used and the rear box. Jun BL boxes sold by ET sound insane and i havent managed to find something that sounds better as yet.
https://www.sau.com.au/forums/topic/202758-exhaust-places/#findComment-3598205
Cory from Fisher Performance for a full custom setup with your choice of mild or s/steel.
He's got some great ideas for what works with a twin turbo setup at very good prices.
My 34 GTR is booked in next Wed.......tell Cory that Pete the Investigator sent you and he'll look after you.
https://www.sau.com.au/forums/topic/202758-exhaust-places/#findComment-3598472
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
