Hey guys just after some proffesional clarification as I find this a tad confusing. I have an 2000 model R34 non turbo that is 2 door but AWD. A mate of mine beleives it is a GTS4. Now from reading this I understand that i need GTR suspension? is this correct? or is there R33 suspension that is suitable for me? Basically I just want to lower my car and stiffen the ride and have been told that coilovers are my best option. Its not a track car or anything so it doesnt have to be brand new or top of the line gear.
If anyone could help me out I would really appreciate it.
Cheers.
Unfortunately R34GTS4's are not the same as anything else. So you can't just grab a complete kit, it's a mix and match exercise. Being a 4WD the front shocks have to be the short style, like an R32/33/34GTR. But it doesn't have the same weight on the front (no turbos, no intercooler, smaller gearbox etc) so you need a lower front spring rate and lower spring free height than an R33/34GTR. At the rear the R34GTS4 doesn't have the alloy rear hubs that R34GTR's and R34GTT's have, it has cast iron hubs like an R33GTST and R34GT. That's why an R34GTS4 needs the rear shocks with the eyes (like an R33GTST) not the forks (like an R33/34GTR). The rear springs in R33and R34 all models are the same.
A summary of what you need;
R33/34GTR front shocks
R33GTST or R34GTT front springs
R33GTST rear shocks
R33/34GTR, R33GTST or R34GTT rear springs
Cheers
Gary
  • 3 years later...
  • 3 weeks later...
  • 3 months later...
Okay so i have a sedan 1999 R34 25gt-v.
What are my options here?
It is an N/A but i'm almost one hundred percent sure that a gt-v has the exact same suspension set-up as a gtt.
Therefor giving it the eye fork set-up i guess.
I assume from the previous posts i cant transfer coil overs from a coupe into my sedan?
Are there any previous model skylines ie. r32/r33/ coil overs i could purchase that i could just drop straight in?
Any help would be much appreciated :)
Cheers Tony.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
