I'm almost at the process of purchasing new coilovers for my 180sx (Tein Mono-Flex) and they come with spring rates of F:7kg and R:5kg.
Now, the plan for the car is to get new wheels and run RE55s on them, yet I have the feeling the spring rates on the coilovers may be too soft.
Can anyone confirm whether or not they will be sufficient?
Worst case they will be a good starting point. What tyres are you planning on running ?
The Mono-Flex are meant to be a decent shock, better then the Super Street and there are plenty of happy/quick cars running around with them. LOL, i havent forgotten either about looking for some shocks for you, problem is i keep finding S14/15, not S13 ;)
F:7kg and R:5kg sounds stiff enough assuming you still drive a car a bit on the street.
what other suspension mods do you have?
its very common for 180sx/s13 to run high spring rate, but that doesn't mean a high spring rate is better, there are alot of factors which you need to take into account.
like afew mention above its a good starting point, if the car feels to soft then you can easily buy some larger spring rates locally.
all so in my personal opinion there is nothing wrong with running a large spring rate like 10/10, but each to their own :)
Roy look here for s13 coilovers http://search1.auctions.yahoo.co.jp/jp/sea...ode=1&apg=1
Yeh, but they are all crap, im on the lookout for one of 3 models of shocks. Otherwise the SK GB is the best alternative. A few S13 guys in NSW are running them to good effect
Have no other suspension mods at current, but plan to install front and rear swaybars as well as bushes, and maybe castor rods when the coilovers get installed. I also have a daily driver, so the main intention of my car is for track/motorkhana events. It doesn't matter too much on how streetable the car will be, because it will rarely be driven on the street. (Although it will remain registered).
Troy, I've budgeted for new coilovers now, so probably go down that route lol, plus I plan to be running RE55's.
Personal opinion here. I wouldn't worry about most of the bushes straight away if they are in reasonable condition, definitely get the caster rods.
I would add adjustable rear upper control arms and alloy subframe collars to the list.
Other then some Nismo replacement lower control arms, what do S13/R32 owners do to freshen up the lower control arms? Moonface do new bushes that are meant to also help with correcting the roll centre of lowered cars...only i start to get worried about having too much adjustability in the suspension as i fear you will spend forever and a day chasing a good setup :D
I just re bushed mine with noltec poly jobs and added some mfr roll center adjusters on the rear and copy ones on the front. I swapped to an s14 front LCA recently to get more camber/track so need to rebush that eventually.
They're not adjustable so its just a case of setting the ride height to maintain the LCA geometry, and then play with ride heights to alter your roll center if you want to do it that way.
You don't run your car that low anyway do you roy? You may as well save the money on the non adjustable RCAs
Bushes need to be changed because they are standard, and have deteriorated and cracked, so I figure whilst doing all this other suspension mods to the car, why not do the bushes at the same time :banana:
So the general consensus is that the spring rates above will suffice for track work?
LOL, you the man! You have done all the rehash work on your R32 already so making my learning curve so much easier. THANKS! :banana:
Do-Luck...what wheels are you planning on running, You were having problems with rubbing last time out
I'm going to run Work Emotion XT7's in 17x9 +17... The main problem I had with rubbing with my current wheels is mainly due to my worn out coilovers, and not having enough camber.
I really hope you have wide guards :glare:
By the time you put a 235 re55 on those wheels i reckon you will need at least 30mm extra width on each side at the front and maybe 20mm at the rear
The only s13's i know that have been able to run 235's up front with stock guards have been dumhedz NA nugget thats at almost stock height with pretty ordinary offset wheels and too_much_boosts sil80 and he also had to wind the front height right up to stop it scrubbing with pretty ordinary offset wheels (he had to use a 2mm slip on to stop the tyre hitting the strut as well, so pretty poor offset).
I'm not 100% certain about the offsets, but sort of just getting some ideas at the moment. Main thing to sort out is the suspension first.
Would you maybe suggest I run 17x8 +25 up front, while leaving the 17x9 +17 on the rear?
I wouldn't advise using the guard clearance to determine how much camber you run. Different circuits demand different cambers and (more importantly) what you run on the track should be far more than what you would want to on the road for tyre wear reasons alone.
For tyre clearance you would be best advised to use a strut leg with more than standard offset to the upright (hub). This gives room for camber and also enables you to run wheels with more offset (inwards) for increased guard clearance. We have run 235/40/17 A048's on 8" rims with camber between 1.5 degree negative (road) and 4 degrees negative (Philip Island). This requires adjustable strut tops and offset camber pins.
Cheers
Gary
My car isnt overly low. That said i cant find the listing on FAST for OE replacement lower control ball joints that bolt to the hub. Noltec may make inner arm bushes, but not the ball joints that bolt to the hub. (excuse me if i am using the wrong terms).
Your terminology is correct enough that i know what you are talking about :P
The only reason i'd suggest steering clear of the RCA's is that they effect the track and camber once they are installed. I had major issues trying to regain front camber after i fitted them (s14 LCA was needed to get me back to around the 3 degree mark). Rear was ok as i had adjustable upper arms but i then ran into problems with the inside of the rear rim scrubbing on the LCA (it was close to begin with) until i spaced it out a bit further.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
