Basically I have 5 stud hubs from 32 GTST with 4 pots and dba 4000's
im interested to know if the 4 door has 5 stud available or are they 4 stud, and also would it be a complex operation to do a conversion as i really want to keep the brakes
im also hoping that the coilovers from my 2 door are still guna work on the 4 door.. they are teins
id be keen for undercar images if anyone has them
edit: i have been told 4 doors have 4 stud but lots of pics i look at are 5 stud.. are they all 5?
Edited by BANGN
https://www.sau.com.au/forums/topic/203486-r32-hubs/
4 stud for NA 5 stud for turbo. the 5-stud setup will bolt straight onto the 4 stud hub carriers. see this link for a quick overview.. http://www.nissansilvia.com/forums/index.php?showtopic=38124
it is a s13 but the procedure is the same.
https://www.sau.com.au/forums/topic/203486-r32-hubs/#findComment-3608455
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
