Hey all,
I have a R33 GTR and i am looking to get an exhaust done on it... ive asked around got quotes etc etc...
Ive been quoted any were from $2200 to over $4000...
Now i was looking through nengun.com at there exhausts they offer and came across these two items...
http://www.nengun.com/trust-greddy/mx-front-pipe
and
http://www.nengun.com/trust-greddy/titan-composite
Now if i team those two items up together would that work?? or what am i missing!!! as this would only come to $1155.65 which is much MUCH cheaper than any of the quotes i have got...
What am i over looking?
cheers
https://www.sau.com.au/forums/topic/203550-exhaust-help/
Hey all,
and
cheers
What are you overlooking?
Well for a start, good luck finding stock of the Titan Composite system.
Second, you have not allowed for freight.
Third, you have not allowed for the tax and duty you will be paying when the exhaust arrives.
Its not like importing a Power FC, the exhaust box is massive and you will more than likely need a customs broker.
How exactly is the above MUCH cheaper than anywhere here, when a quick look through the trader forum reveals you can have a new Kakimoto Regu 06&R cat back for $895, and Stainless JJR Front Pipes with local warranty for $299?
https://www.sau.com.au/forums/topic/203550-exhaust-help/#findComment-3608813
Ok cheers for the ideas.... but saying about the JJR Front Pipes for $299 (thats the ones Just Jap sell right) has anyone used them? are they actually any good? seeing as brand name ones retail easily double the price?
https://www.sau.com.au/forums/topic/203550-exhaust-help/#findComment-3608937
I looked at them recently when I was there and they are very similar to the HKS type and the build quality appears to be very good.
https://www.sau.com.au/forums/topic/203550-exhaust-help/#findComment-3608947
thanks for that... have contcted them and Steve sounds quite good.
Only problem i dont like is the exhaust cannon is only Titanuim looking not a real titanium tip.... Not into fake things...
The dump pipes would be good if i knew they worked well...
https://www.sau.com.au/forums/topic/203550-exhaust-help/#findComment-3608961
Well how does this sound do you guys think....
- Kakimoto Regu 06&R Exhaust System - $895
- JJR Stainless Front Pipes - BCNR33 - $299
- X-Force Stainless 3 Inch Cat - $160
Anyone had any Kakimoto Exhausts? any good?
I just want to do it once and do it right... for performance, sound and looks......
https://www.sau.com.au/forums/topic/203550-exhaust-help/#findComment-3609717
Yeah mate I have the exact exhaust you're thinking of. Looks great, very quiet system.
https://www.sau.com.au/forums/topic/203550-exhaust-help/#findComment-3609782
well bud. u see in your first pic of the system that u uploaded?
it has a rear cannon, a cat and a =mid muffler.
the mid muffler helps heaps. i had one with a jasma muffler, sounds like a camry, whisper quite. but when i took it out, it was loud as.
the mid muffler acts as a baffle, which im sure u already know, and helps to suppress the sound. u do lose power but its only about 0.0002hp, but is worth it.
especially for a gtr, u dont want to attract any more attention ay.
https://www.sau.com.au/forums/topic/203550-exhaust-help/#findComment-3611609
I have a r33 s2 GTST with a JJR stainless front pipe. Different kettle of fish the GTR, i know... I was happy with the integrity of the welds and bends on the JJR front pipe, and the fit was ok, but I did have to change some of the studs off the turbo to bolts as I could get nuts on a couple of them due to the shape of the pipe.
https://www.sau.com.au/forums/topic/203550-exhaust-help/#findComment-3612022
cheers...
the jjr stuff sounds good and had a lot of good feed back.. might go for it
https://www.sau.com.au/forums/topic/203550-exhaust-help/#findComment-3612154
Well i think ill go for the kakimoto.. unless anyone can suggest a slightly louder version???
Also any one seen it anywhere any cheaper??
https://www.sau.com.au/forums/topic/203550-exhaust-help/#findComment-3613954
Yeah I have the $160 hi-flow 3" cat converter
with a bellmouth Just Jap stainless 3" front pipe (turbo to cat) for $220
plus a Kakimoto gtr racing 3" muffler for $100
with custom 3" pipe from cat to muffler at exhaust shop
much cheaper than 2k plus
kakimoto mufflers sound horn and are free flowing
JJR dumps are good value for money
I wish tho I got a big body cat converter.......
https://www.sau.com.au/forums/topic/203550-exhaust-help/#findComment-3614082
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
