  • Replies 327
Posted Images
Guest courtney
Hey guys,
I work at Hills n da boss told me last week that you're alllllll coming down! I am so excited, it should be a great day. Fingers crossed the stupid sun comes out!
Look forward to seeing you all there, tell EVERYONE!
Courtney!
you can make your own award too :)
Ill call it the Big Dick Award
Thats what driving an S4 is all about
no one knows you have it, untill you use it, then not much needs to be explained afterwards
Guest courtney
Do we still have it? I haven't seen it in the shop! Did you send that fax through today with the wiring diagram too?
If we need to hunt that PFC I shall remind him indeed but I honestly didn't know what happened with your car, I went home and when I came back the next day it was gone!
SO SAD :D
Lol anyway yes I will just remind him of whatever it is he is meant to be hunting for you.
well thats what you get for taking saturday off :D the boys welded up a beautiful 3" turbo back exhaust for it but the PFC still needs to go in, I guess he has been looking into the wiring :laugh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
