Hi all,
I have 3 questions regarding maintenance for an R34 GT-R V-Spec II.
1) Where are the jacking up points for the front and rear? Do I have to take off the F/R under diffusers before jacking up?
2) Where is the best place to put the Jack stands?
3) How do you take off the oil filer without causing a mess, because I had a look down there and it looks fairly tricky.
Any info would be greatly appreciated,
https://www.sau.com.au/forums/topic/203743-r34-gtr-maintenance/
Hi all,
jacking points should be the same with 32 gtrs...at front cross member well with 32 has n X shape centre of car and the rear just past the diff there is a jacking point there as well
some people mount the jacks on the rails but not really good idea as you dont want to damage the rail, in the manual shows where you would jack the car up if u had a flat n use those points..just rear of front wheel n front of rear wheel....personally use the cross members.
yeah that sucks unless you have a hoist, placing rags under the oil filter location as your taking the filter out may minimise a mess..or get a oil filter relocator, saves you hassles in the future.
hope that helps
HA! install a remote oil filter, but thats a head f**k of a job cuz there is hardly any room to move in the engine bay.
As what godzl1975 said, use the rags or what I do is after getting the oil filter on, I spray around the filter with degreaser and the rinse of with water.
I hated jacking my Skyline (more specifically, where to place the stands)
The Rail's are fairly weak and i dont wanna crush em. The Sill's are a big no-no for obvious reasons (one of mine was squashed flat when i got it)
I used to use the curved section, front / rear, just near where the lower control arm attaches to cross member/rear cradle. I didnt like the idea of living under the car for days like this though.
Figuring Nissan designed the sills to take the weight, (as per manual) a mate, Apex Trudger made me up some thick dense rubber blocks with slits (in which the sill sits in) I place these on the jack stands.
I jack it where everyone else does.
Good point bout the front diffuser, from what your saying it sounds like the R34 one covers the x-member?
Edited by GeeTR
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
