Is This A Decent 1/4 Mile Time For What It Is?
Fancy it getting to the point where Ozzies would consider importing f**king Datsuns from the US?
So the issue only occurs when indicating right, AND you're missing a bulb in it. Normally on old flasher relays, when a bulb blows, they start to flash quicker. If you have potentially another short, or a couple of lower resistance bulbs, the constant noise you might be hearing is actually the flasher relay dropping in and out really quickly. I suspect if you get your front indicator wired in, your symptoms will change...
