Hi all,
Can any fellow Perth based Stagea owners recommend a place to get audio install work done? I'm looking for people that acctually have worked on stageas before, not the ones who are willing to "give it a go" as they usually break something in the process :D
Cheers!
alternatively, if you dont want to pay a shop to do it, i've mucked around inside the dash of kylies stag, and can give you a hand. :D
+1
unless you are going to install an in-dash DVD player with a roof mounted screen
Then i will run away screaming and flapping my hands like a 10 year old girl :D Been there, done that and have the therapy bills to prove it.
Have'nt contemplated doing this yourself or phoning a friend with a day or two to spare?
If you have the know how, do it yourself as you know you will take care or your pride and joy,
save $$$$ and learn a bit about working on your car.
Manufactures design everything to pull apart soooo easy these days, Nissan/Toyota/Ford especially easy to work on.
Or see a helpfull person like Mitchy.
sounds like a plan mitchy.. what did you do to kylie's stagea?
well.. it originally had a deck/amps/subs/speakers changed, and i removed the deck/amps, to rewire them as it was all over the shop.
the rest of it is pretty straight forward, many a car has had its guts spread out all over our driveway. :P
I wouldnt mind giving it a go myself, but I've never wired an amp before and dont know whats involved etc.. i'm sure i'll be able to do it after someone has shown me how once.
The car has a japanese pioneer carrozeria GPS/TV unit which I was going to ditch, but i managed to wire my ipod to it and got both audio and video running sweet so its a keeper... took two days and i lost some hair, but worth it.
Where do you live mitchy? and what beer do you like?
Edited by Scratch
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
