AUTOSALON 2008
Definately In:
NSA11N - Paul - R33 GTST
OMG-RLX - Kon - R33
Sheng - Albert - R34 GTT
Joeyz - Joseph - R34 GTT
DRD-OOF - Steve - R33 GTST
Kuma J - John - R33 GTST
Brycey - Bryce - Stagea
MattD - Matt - R34 GTT
Lauren - R33 GTST
Zilch* - Steve - R33 GTST
Sl!m – Sam – R32 GTST
Lil Bobby 260 – Bobby – Autech 260RS
Travis32 – Travis – R32 GTR
Xmetal – Ian – Stagea
Maybe In:
Jeffworld2 - Jeff - R33 GTST
ZCR - Zane - R32 GTST
Shane666 - Shane - R34 GTT
Malcolm - Malcolm - GT2500R
NXTIME - Charlie - R32 GTR
Yidz - Christian - R32 GTST
airbournesoldier - Scott - R33 GTST
Bullet32 - Steve - R32 GTST
UPDATE
________________________________________________________________________________
AutoSalon Show Series 2008
Show #2 Sydney
Date: 21st - 22nd June
Cost: $100 entry + $40 (a small amount to cover power, lights and other props etc etc)
TOTAL $140
ENTRY FORMS CAN BE FOUND HERE
or copy and paste below link
http://www.autosalon.org/PDF/entry_form_08.pdf
Please not Final Battle will still be held at Homebush Showgrounds
Theme/ display - Car Showroom
Flooring - Woodern panels with raised flooring in middle
Price - $100 for entry + $40 to help cover materials and power
TOTAL $140
I will now need to know who is definately displaying their car in the show.
The cut off date for money and entry forms will be WEDNESDAY 9th MAY
Why is this so early you ask?? If we get our money and forms in early, we all get a free Buddy Pass for the Show!!!
SAU BANK ACCOUNT DETAILS
Bank: NAB
Account name: Skylines Australian NSW
BSB: 082 -356
Account number: 54-639-3766
Please put as much detail into the transfer description as you can - Your SAU USER NAME and AUTOSALON would be quite helpfull
https://www.sau.com.au/forums/topic/204621-we-want-your-skyline/
  • Replies 487
Posted Images
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
