Im trying to deceide which plenum to go for.Its either Greddy or Plazmaman.Seeing how the Plazmaman item is only the top half does this mean that the top half of the stock 33 plenum is the most restrictive?
Will the lower intake runners support 500hp?
Both are very good items,will it just come down to what look i want in the engine bay?
https://www.sau.com.au/forums/topic/204727-plenum-choice/
Depends on your choice, but i'd go the greddy. The full intake replacement is best for both big or low power because it will add some responsiveness.
Which one suits your budget? Making 500hp isn't cheap. Add that and you have the answer.
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3626656
dave you should give plazmaman a go if its not all drag, keeping the longer runners is a good idea for low down. I havent made this decision yet either, but thats because i dont want a plenum that looks like it is custom ie polazmaman's curvy thing. i want one that looks like it 'might' be nissan
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3631092
what throttle body you planning to run?
Greddy i think is setup for the Q45 - and you need an adapter for the std one
Plazmaman is setup for the std one, im just starting to look into what i have to change on mine to fit the Q45
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3631104
hypertune has better flow then the greedy item
cost 2200 with any size throttle body
killer plenums but for 2200 forget it in this application, unless your after every poofteenth NYTSKY.
Used one on a 300awkw+ EVO 6.5 TME and it was the best plenum ive seen... the TB was average though.
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3631170
Topsecret has plenum for around 2K with Q45 Throtle body. looks pretty sexy IMO its the best one on the block in looks and performance. look at nengun or topsecret site.
Greedy I think someone is selling one on this site for $700 i think in perth do a search.
I guess if im on a budget i go greedy if i wanted all out i go topsecret looks dam impressive.
You get what you pay for, if you try to sell it later you will get good return on a jap product than an imitation one.
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3631231
got power figures & graphs of cars with said top secret plenum?
or are you pulling this out of ur behind caus it looks all pretty?
https://www.sau.com.au/forums/topic/204727-plenum-choice/#findComment-3631337
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
