that is actually one of hte better ones.
Fun isnt it!! I sat in the car while one of the guys pulled apart half the dash to get mine out. The cdplayer and tape deck combo have now been sent off to clarion to see if there is any hope in hell of repairing the deadly "cd error f0" code i have.
Dont like my chances as everything ive read shows up with it being kaput.
Sorry for the hijack, just reminded me of what my car looked like about a month ago!
Laine
wow...hope you can piece that back together without any scratches lol...
btw...how good are the bose systems in these cars?? Are they as good a quality as their home theatre systems?? I'm contemplating getting a V35 GT-8 possibly soonish..:banana:
btw...how good are the bose systems in these cars?? Are they as good a quality as their home theatre systems?? I'm contemplating getting a V35 GT-8 possibly soonish.. :D
Others might disagree but I think the Bose is fantastic for a stock system. I'm usually one to upgrade systems straight away when I buy a car, but a year later, I still have the stock system. It still takes my doof doof, no audible distortion, just needs some dynamat in a few places to make it sound tighter. Go the GT-8!
Stock - MP3's no, CDR's yes. Luck of the draw of course if your headunit works in the first place. There's been a number of reports of units being DOA. But just one of those things you need to consider.
keep in mind the stock bose setup runs
nissan head unit
bose amp
2 rear parcel shelf bose speakers 6*9"
2 rear seat bose speakers
2 front door bose speakers 6.5"
2 front door tweaters
the sedan also has a sub i think doesn't it?
not bad for a stock system, certainly would cost a fair bit to put together this kind of quality off the shelf of an audio store. the only way you'd get better imo is adding top quality items and unless you are into audio massivley you probably wouldn't notice the difference
I actually went and test drove a 350 gt-8 sedan today and brought along one of my R&B Cds...and the bose system rocks! And yes..the rear parcel shelf has a sub too....pity a bloody child restraint was fitted straight thru the speaker grills!
nissan head unit
bose amp
its does. 8" version with an amplifier strapped to it. I still reckon I could do better :no: but for stock it works quite well.
Jon,
they pull the sub out , put a bracket over it drill the hole and put a kidbolt there. watched them do one today.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
