Stolen - Silver/blue Two-tone S13 Silvia : Prahran
Thread on Nissan Silvia with details - http://www.nissansilvia.com/forums/index.p...howtopic=285584
Stolen last night (6-Feb) from Prahran.
Sparco rims, FMIC, sunroof, 2-tone - otherwise stock looking.
Has Apexi P1 exhaust but not too many other identifying parts.
Contact details in NS thread.
Thanks
J
My sister live's in Prahran and 3 weeks ago her car got broken in to. They used a glass sucsion cab to get the window of and used a crow bar the yunk the side of the bonnet up nere the battery to take of the turmals, So the aleam wouldnt go off.
Hey guys, this topic is about my car, my number is 0400888592 if you see or hear anything, there is a $200 reward for any info that leads to me getting the car back, walking down the street there seems to be alot of broken glass on some spots on the road, i alos hope i find it, if you guys can keep an eye out it would be greatly appreciated, maybe i'll buy a r33 if it dosn't come back
Hmm. My mate's Soarer got broken into in Prahan a couple of weeks ago also. We need to organise a hunt.
i just drove around all the near by streets it took me over three hours, and i went around chadstone car park but i didn't find my silvia, hopefully with all you guys keeping a eye out that should cover alot more ground
so much for living in a posh'ish area!
hopefully you have some luck in finding it
huh, more like a crime filled area, i live in a apartment building and it has a locked laundry that me and another friend of mine share, three weeks ago someone climbed the outside drain pipe went through the window on the second story and stole both of our washing machines and a dryer in the middle of the night, the hall way of the apartments gets graffiti every second day, its not just the building im in its the whole street, on chapel street the homeless are on every second corner, thats why i just brought a house a few weeks ago in croydon. i only had 11 days to settlement
Its actually a great place to live during the day, its just at night and on weekends when the 'tourists' come in a get loose. Same with St Kilda.
Surly matt will give you a discount on a car ;)
993 turbo with police flack jackets and MP5's in the front thanks, then ask him "whatcha gonna do"
I crack myself up.
BUT best of luck finding the car fingers crossed it shows up in one piece, and the thief, in many pieces.
a decent alarm will have a backup independent power source to avoid this old trick.
A DECENT alarm will have a set of flame throwers under the car that torch the mother f**ker that touches your car. However this is illegal in australia ;)
bah some one should make that legal would hate if some one stole my car with all my hard work put into it i be pissed off im sure gonna spend allot of $$$ in an alarm
lol, i would of been good to something like dead locks with a alarm that lock the doors after someone tries to start it and there in the car, so when you go to your car and there is someone locked inside, well you get the picture, :) . thanks guys for keeping an eye out, i really appreciate it
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
