Does the corolla happen to b made in or around 1986, and have a 1GGZE in it or something?
A mate of mine has a supercharged AE86... I don't even know what a starlet has in the engine bay... I thought it was like a second boot...
my friend has a corolla thats supercharged! just wondering if anyone heard of or have a supercharged starlet?
4E-FTE is the jap spec turbo starlet engine. Mate did the conversion to a local model starlet a few years ago, it had guts.
the corrolla would have a 4AGZE from the mr2, zippy little motor.
As for the starlet as mentioned it has the 4E series motor, being such a light car i would expect it to hall some ass :no:
there is no "factory" supercharged/turbo starlets.
I'm sure it's doable, but would be a lot of money for nothing.
I'm assuming you have the aus delivered shopping trolley version.
you can turbo charge that..
or engine conversion from the jap spaec EP82 starlet which has the 4e-fte turbo 100kw engine.
Sydneykid had once mentioned that he knew of someone who had shoehorned a sivler top 20 valve 4age in to one.
those motors are 118kw I think..
was apparently a bit of fun to throw around.
I read about a 20 valve starlet years ago, it was built for circuit racing, power to weight was very good - what it lacked on long straights it made up for it in spades around the corners. From what I remember, the biggest hassle was making an exhaust manifold to fit
Wasnt there an overseas model starlet with turbo from factory?
surely?
I remember seeing a few in Malta few years ago (yep, malta! lol same sorta shape as our late model ones, just different headlights and such)
And then theres the Jap ones from the late 80's
surely?
Yep, in Japan there was the Starlet GT, and the newer Starlet Glanza, both ran 4E-FTE engines.
what's wrong with knowing about cars other than nissans?
take your blinkers off and look around the rest of the stable and see how many cars are around that will hand you your arse.
People of the 90's will know how much fun Switft GTi's were to drive... this is before the import days so some of you can go back to sleep...
the EP82 Starlet GT was about the same weight but had about 10 kw more than the swift.
and more torque due to turbo.
they are light, fun cars to drive.
no dori dori so that rules out some more of you.
a stiff rear anti-sway bar makes a world of difference to the handling.
it is not uncommon to see these cars lift their opposite rear wheel when cornering hard.
small article from back in 1999 in hot 4's when whiteline did a kit for them
http://whiteline.com.au/articles/RH45_star_a.htm
and ofcourse, just like SAU is to skylines..
http://www.austarletclub.com/ is to starlets.
do a little digging. expand your minds.
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
