RubyRS4 Posted March 13, 2008 Share Posted March 13, 2008 lol! I wonder what is 'normal spooling noise'? Can anybody with a S2 that is 'normal' be bothered to record the turbo sound on boost? That might give those of us who suspect something is wrong a better idea... just a thought... objviously if you have an exhaust which covers it up that might be hard I've still got the stock system. I've just never paid attention. I'll endeavour to 'listen out' for what is normal and try to report back here. Link to comment https://www.sau.com.au/forums/topic/205300-stagea-s2-turbo/page/2/#findComment-3716770 Share on other sites More sharing options...
Duncan Posted March 13, 2008 Share Posted March 13, 2008 the turbo shaft should not move more than 1-2mm in and out, and less than 1mm side to side. any more than that and it is on the way out Link to comment https://www.sau.com.au/forums/topic/205300-stagea-s2-turbo/page/2/#findComment-3717183 Share on other sites More sharing options...
DaveB Posted March 13, 2008 Share Posted March 13, 2008 the turbo shaft should not move more than 1-2mm in and out, and less than 1mm side to side. any more than that and it is on the way out Thanks Duncan That's good news. When I had mine apart I'm pretty sure it had less than a milimeter; will try to check again. I could feel no play side-side. Link to comment https://www.sau.com.au/forums/topic/205300-stagea-s2-turbo/page/2/#findComment-3717415 Share on other sites More sharing options...
STAGE1 Posted March 13, 2008 Share Posted March 13, 2008 Hi all I have a S1 until just recently all I had was a nice turbo whistle. What I had was a very loud sound something like a mettle Bering grinding away at high revs. It turned out to be the exhaust manifold. I had two broken studs and the manifold was loose. I tightened up what I could now we are back to just the turbo whistle. I am doing some work on the car the week after Easter so I will try to fix the two broken studs then. cheers phil Link to comment https://www.sau.com.au/forums/topic/205300-stagea-s2-turbo/page/2/#findComment-3717455 Share on other sites More sharing options...
STAGE1 Posted March 13, 2008 Share Posted March 13, 2008 Sorry forgot to add prices for the gaskets Exhaust studs 3.80 X 12 Turbo gasket inlet 31.92 Turbo gasket outlet 28.34 Manifold gasket 94.09 All jenuin nisan + GST Cheers phil Link to comment https://www.sau.com.au/forums/topic/205300-stagea-s2-turbo/page/2/#findComment-3717474 Share on other sites More sharing options...
DaveB Posted March 13, 2008 Share Posted March 13, 2008 (edited) Hi allI have a S1 until just recently all I had was a nice turbo whistle. What I had was a very loud sound something like a mettle Bering grinding away at high revs. It turned out to be the exhaust manifold. I had two broken studs and the manifold was loose. I tightened up what I could now we are back to just the turbo whistle. I am doing some work on the car the week after Easter so I will try to fix the two broken studs then. cheers phil Oh, broken studs... good luck hope you can get the old ones out Is an exhaust manifold gasket really $94 from Nissan??? Think I will look at aftermarket ones if I ever need one! Edited March 13, 2008 by DaveB Link to comment https://www.sau.com.au/forums/topic/205300-stagea-s2-turbo/page/2/#findComment-3717715 Share on other sites More sharing options...
STAGE1 Posted March 14, 2008 Share Posted March 14, 2008 Hi All I am not looking ford to working on the broken studs but it has to be done. I am hoping that the other 10 will come out easerly (If 2 are broken the others may be close to being in the same condition hence the reason for doing the lot). I thort that $94.oo sounded a bit dear but I got it anyway Cheers Phil Link to comment https://www.sau.com.au/forums/topic/205300-stagea-s2-turbo/page/2/#findComment-3720736 Share on other sites More sharing options...
DaveB Posted March 14, 2008 Share Posted March 14, 2008 I am hoping that the other 10 will come out easerly (If 2 are broken the others may be close to being in the same condition hence the reason for doing the lot). true... good luck! Link to comment https://www.sau.com.au/forums/topic/205300-stagea-s2-turbo/page/2/#findComment-3721524 Share on other sites More sharing options...
DaveB Posted March 18, 2008 Share Posted March 18, 2008 I've still got the stock system. I've just never paid attention. I'll endeavour to 'listen out' for what is normal and try to report back here. Hey Reuben what can you hear ? My turbo is pretty noisy to my ears; I can pop the bonnet and rev it a little and it sounds like a noisy fan. When it's making full boost (with the high boost mod, so it happens at ~2,250 RPM and there's less engine noise to compete with) it sounds like a pretty loud noise, bit like a jet plane taking off but not that loud. Not loud enough now for people on the side of the road to hear - I don't think - but disturbing. Dunno if it's normal... will try to record a sound clip for you all... Link to comment https://www.sau.com.au/forums/topic/205300-stagea-s2-turbo/page/2/#findComment-3730688 Share on other sites More sharing options...
