Originally posted by Initiate
Agree on the waste of a nice car, but shouldn't the emphasis here be on the poor sod who probably isn't alive anymore, or at the very least very seriously injured???
Amen brother!
screw the car, i feel sorry for the ocupants.
https://www.sau.com.au/forums/topic/2054-funeral/#findComment-38065
Originally posted by carlo
Thats what happens when you lose control of your car. If your not in control then your not going to have much luck.
The 2nd photo is a good example why we have to have intrusion bars on our imports. Why they dont have them in japan is beyond me.
R33's and R34's have intrusion bars as standard.
It's a cold hard fact,,,if you race hard on the street that sort of crash is always a possabilty....The 1st cars not that bad,,,,the rear end has absorbed most of the impact,,,the o/s/r 1/4 has done its job very well. As for the 2nd pic ,,,well hope no-one was in the passenger seat,,,,. I see this crap on a regular basis,,,,We actually drive a VERY safe cars......Sick person I am,,,,,can I have the Wheels off the 2nd car,,,they look okay.
Neil.
https://www.sau.com.au/forums/topic/2054-funeral/#findComment-38883
Side intrusion bars would (and did) do sweet FA on the car that poled the passenger door!
Just thought I would make mention of the two pictures I contributed to wreckedexotics.com :)
http://www.wreckedexotics.com/cars3/new/35..._071902_04.html
http://www.wreckedexotics.com/cars3/new/35..._071902_03.html
https://www.sau.com.au/forums/topic/2054-funeral/#findComment-38954
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
