  • Replies 70
thats funny. you bought a $$ car from a shop and they didn't bother putting in $20 worth of new spark plugs? remind me to buy a car there sometime
and the same bloke reckons you can get less than factory boost using a boost controller eh? the laws of physics must be different on the north shore
Another note. Spoke to Tony from North Shore Prestige where I got the car from. He suggested a few things to increase economy.
- change plugs
- clean injectors (if they do need cleaning but unlikely he said)
- clean the afm
- get an ebc so you can wind down the boost to say 5 pounds when you dont need the power.
- dont drive with a heavy foot, which im not anyway.
Y get an ebc to wind it down to 5 when that is stock boost under 4 grand. I use a switching system so I can run stock and switch to about 81/2, if the gauge is accurate, when I need some hustle off the lights or hitting Henri Robert on the way back from the coast.
I think the system I built cost about $30 for the two switches.
Sure an ebc gives a whole lot more range, but if you have a std turbo why blow it.
The best mod I have for a virtual stocker is a 3" JJ dump, 3" X Force Hi Flow cat, and 3" cat back. I still have another muffler and a Japanese EPA canon that keeps the car super quiet but the 3" system lets it breathe a lot better and you can really feel it
I have a DFA ready to install. I've had it for two years. But every time I go back thru all the threads etc., even SK's epistles
I am still not entirely convinced that a DFA will signifficantly reduce my fuel consumption because it has absolutely NO CONTROL over my right foot.
Even at 151.9 for Ultimate today I am still happy with the thrill that driving at 16/100 gives me in a very safe vehicle that has a capital cost of 15 grand.
ROFLCOPTER!
Why don't they just buy a Prius?? LOL
Just came back from a run from the ACT to Sydney and back over the weekend (only the 2nd time in 2 and a bit years). Only engine mods are 3" Split Dump, 3" all the way through a hi flow Cat, two pass through mufflers and a high flow air filter. Oh, plus my connection with the battery terminals failed the other day whilst travelling at 80k's an hour (completely dead, no power at ALL, engine off, a long downhill run ahead - another story) which nicely reset the ECU after I had just had it serviced. It just required a quick fix of the battery terminal.
We headed up the road towards Sydney on the saturday. I filled up at Sutton Forrest, stopped at Sutherland, next day through to the North Shore, back through Sutherland, up towards Picton, back on the Freeway towards Canberra and home (love those freeway on ramps ;-> ). Managed to make it all the way home to my local servo, where I filled up. It was on the Orange light for a while, and took exactly 60 Litres to top up. 520k's.
Very happy with that. Got to get the audio system replaced though, although the sweet sound of the turbo partly on boost at the occasional cruise at around 3,200k's was a beautiful thing. :D
I've been consistently getting 11L/100km drving to and from work, which is a 120km a day. I'm impressed with it, since the factory figures are around 12L/100km. not too bad for a 12 year old car with over 200,000km on the clock I think. 161c/L for Ultimate is starting to hurt though, hopefully someone buys the old girl in the next month or so so i can get myself a little 4 cylinder runabout to save some money on.
interesting, the last time i posted here i was getting around 14.5L/100km, but ive done a few tanks on vortex and synergy 8000, and im getting 13.5 or less L/ 100kms probably because im taking a different route and avoiding the traffic. getting up at 6am gets old though :P
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
