Also spotted a Gallardo today in the BP on north east road i think it was, Very Nice..
And saw Simon-R32's drift R32 in All Type Crash as i dropped my GTR off there today, very nice looking car mate, love the colour..
And lastly, DARE YA's ex magna being driven down south road at reynella, good to see its still down south. Got black with silver letters on the plates like you had haha. Couldnt see what they said tho.
Cheers mate but thats actually Hayden's car that bright orange one with All type down the side :) he's the bloke who'll be repairing your GTR. Very nice GTR btw i was down there today.
All type seems to be full of skylines atm!
saw a dark blue 32 at the hungry jacks near TTP at about 12.30am and right behind was a white 31 that was pretty clean!
and saw a yellow 34 crusing along i think its called military road where west beach caravan park is.
and, a black stagea park at clovercrest yesterday.
Cheers mate but thats actually Hayden's car that bright orange one with All type down the side :blush: he's the bloke who'll be repairing your GTR. Very nice GTR btw i was down there today.
Oh alright. Thought it was yours haha. Looks good anyhow. If his car looks that good, i know mine will look good when its done :blink:
Thanks btw. It will look better without the dent and scrape tho..
I spotted an Silver/Gun Metal R34 GTT 4 Door, with Rays wheels on it, going down Anzac HIghway late Sat night... was full of girls.. hot too!! :blink: It was an auto i think judging by the way the chic driver was taking off then sittin it on the rev limiter before it changed gear... If your readin this i was in a crappy white suzuki swift hatchback... we pulled up at the lights next to yaz about 4 times or soo... pity i didnt have my liner, could have been fun :blush: hope yaz had a good nite n that gal in the back was ok..
later, julz PM me if it was your car... im interested in it!
for sure!... my car is there now... i did this to it last night so you'll see it down at all type getting repaired
Ouch.. Doesnt look good. Yeh im down there next sat to pick mine up, i'll have a look at it while im there.
just spotted 2 lines a burgundy one and a white one both R33 both at the Valley View grand junction rd valley rd intersection gave the white one some loving :blink::blush:
oh also friday night coming home from Pete's house i saw a R33 4door entering the glynde hotel about 2am made me think of sky095 dont know if it was you??
spotted BNR32 i think at their work in parafield somewhere, nice volk rims on it i think with some wickid dish, looked very nice and clean. saw a lot of lines over the past week or so but can't remember them all at the moment.
thanx hunny at least someone would x
I know how u feel kellie, my clutch decided to fail at life on anzac highway, abuse was the most help i got!
Spotted a low, kitted (bn or vertex?) silver 32 with big front mount again, i have the white 34! i think hes on here? also saw him at the plaza a week ago.
i would have stopped for you babe x
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
