spotted kev's stagea out front of his work today?
looks very nice!
yarrr that be mine at southgates. think i heard you boost past. the rims aren't staying though, and the fuel flap is at the paint shop, trying to get colour matched to get some bodywork done and bodykit :/
Yeah that was me! Just dropped into my mates to lend him my buff to get his EVO shinny again lol. haha yeah theres always cars parked round there which makes it a little difficult.. Mine has no choice unfortunatly its always in RWD haha! Thanks, silver still looks great when its dirty from a distance lol. Yours was looking good also, glad to see it on the road, only ever seen it out the front of ur place.
LOL couldnt even tell it was dirty. Only on the road over the weekend, the P's arnt exactly 'true' if you know what i mean - refer to sig lol. But yeah, to the shop and back every now and then is ok, 2 seconds down the road really. Thanks, mine was alittle dirty also, even tho i cleaned it on sunday, damn frost!
Also spotted a black 32 GTS in work (Goodwood Foodland) yesterday with MTV 143 or such on the plates.... I was sitting down with the g/f outside work with the nissan jacket on. car sounded verrrrrry nice :O
yeah that would be Shannon.........cool chic and knows how to drive apparently
yes Shannon is a good girl and knows how to drive :O
i had a drive next to a white R33 this morning with P plates and a trust sticker in the rear window but pretty sure he's not on here :) not too worry
Spotted a silver stag with a Jazmac sticker on the back window on the freeway at about 5ish, and a black Onevia rocking a mad stance on Greenhill road just after the KFC.
Also saw heaps of 34 4drs go past work on North Terrace during the night, notable mentions were a black one with bronze rims ('Nightcrawler' on here probably) and a silver one with a GTR front bar.
think i spotted damo coming out of BP rosewater/grand junction rd... i JUST drove forward out of the carwash and saw ya tried to catch up but commodore got in the way at the exit then traffic lights got in the way hahaha
yep that was me Vu :kiss: Just did a Salisbury -> West Lakes -> TTP -> Salisbury Run
on my travels, spotted RUSH 33 in a carpark, with about 5 cops cars parked nearby
32 4 door parked down the road from my house in salisbury north, been there for a couple of days. anyone on here?
spotted a white R33 chucking a u turn in front of my mates workshop on cheviot rd sporting a sau sticker on front windscreen looked clean was waiting for a bit of boost but no luck didnt wave cause i was in workshop my car was the custom light blue 33 parked out front
spotted a white 33 on north east rd near the bp at modbury. had a sau sticker on the front window. i was in the coona black hr31.
I think my sticker must stand out alright then the blue 33 looked nuts i was trying to find csa and went straight past it
missed the black 31 sorry mate :D
spotted reallly nice blue 32 with fat rims on main nth rd let me in front of him cos some d...head was doing 60 in an 80 zone thanks man
was prob me, midnight blue? i take it this was last night yea? was yours white? gota show the fellow skylines love :D
haha, ya looked right at me...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
