Spotted Scott with Adrian in the passenger seat just before heading to Semaphore, and soon after I spotted a midnight purple R33 GTR with SAU url sticker on the rear quarter windows :)
hey mate what time was it you saw that GTR? i was down that way on my way to grange....
Also spotted last night around 4-45pm silver series 2 r33 plates ERC33 i think got the wave! nice clean car mate.
And this morning around 8-15 a silver 4 door r34 with personalised plates im guessing are aoman numerals lol XXV somthing somthing lol
Edited by Adz2332
Spotted a white R32 driven by a chic on South Rd yesterday. Didn't want to let me merge in to the traffic ... then wanted to prove that she could speed thru traffic. Had SAU sticker on the back ... sorry darl, but wasn't interested in chasing you :/
spotted dave(pinny dave), matty t, luke, flic, and lozz at new yorks last night, nice to meet luke and matty formally! hows the hang over flic? lol
haha hangover is fine :/ Actually felt alot better once we left!
Good to see you again, been a while.. since the CSA days!
Thought it might of been you! It was sometime around 7-7:30pm.
Spotted at the car wash at Golden Grove Village tonight - Bayside Blue 34 GT-R V-Spec II with no plates yet, getting a bath. Looked mint.
If you're on here, I was the one nearby in the black RX-7 :ninja:
Stockish looking pearl white R33 4door on North Terrace about 2am this morning, front was fking absolutely slammed, like he had taken the springs out altogether :ninja:
lol that was me forgot to go up a few lvl on koni adjustable lol better sought that out on sunday too hot saturday 37.
my mate forgot to put it back right the height wise.
just had a quick look its on the lowest setting lol love clamping those springs down to change height :down:
Edited by R334door(s2)
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
