hehe was i drifting my BIG W modified trolley? :D
didnt see you mate
I saw you going past target. You wouldn't recognize me with short hair. :P
Also saw Pete somewhere Southish in the 34...I didn't know the area very well.
Edited by Eddyfier
saw a pure porn bayside blue r34 gtr yesterday arvo on portrush rd i think it was.. had bronze wheels and the perfect stance.
also a silver r33 with enr33 or similar plates, on cold store rd in the hills yesterday for classic adel.
spotted a wine r33 GTR near maccas noarlunga, gave them a wave ? nothing
spotted a black r32 with a big kit on it, huge white nismo sticker on the front bar under the intercooler hole area? no wave? ( down south)
gotta thumbs up from a kid on boosting scooter at least...lol "he wishes it would boost Im sure"
Think I spotted ya Damo! Henley Beach Rd just after midnight about an hour ago - looked around and saw the rear end of a white R34, same rear bumper as yours, white rims....
hrm, dont think so, was on port rd then grand junction rd at like 11ish last night
spotted "SLY" bayside blue r34 gtr on grand junction rd.
quite a few black and white r32/33 a couple grey and maroon ones too
a white r34 and then literally a couple of secs later a silver r34............cant remeber what road it was on tho.
Spotted a dark gray 32 GTR and a black 32 GTR going down South road yesterday!
u sure that wasnt dark blue, i was around there a fair bit yesterday compliments of changing plans had to do a few laps of south rd
reckon i might have seen ur car around the big bend in south rd couple of lights from the expressway.
Edited by Inline 6
Yeah could have been me if it was on Sunday? It could have been dark, dark blue? It was going in the opposite direction (towards the city). Did it have P plates up?
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
