Spotted Howie's 34 (pretty sure) in Boostworx today.
Also spotted a grey 33 4 door being dropped off.
I was there picking up the GTR after it's service + new brakes! Wow... these new brakes are actually amazing lol. I put the pedal down slightly and I nearly go through the windscreen! (that was a slight over-exaggeration)
Ah yours must've been the 32 without it's wheels on the ramp.. looked sweet buddy :P
Wonder did they get my intercooler on yet when you saw it?
Yep Howie, that would have been mine! Just had 4 new slotted rotors fitted + new pads!
Yeah your car was hoisted up and the new guy was working on fitting the intercooler (welding it and stuff)! New guy seems nice, knows his stuff, too! Had a bit of a chat with him.
I wonder if they'll ever move locations?! They're always full to the brim with cars jammed in that small workshop! And now there's 4 of them working!
Edit: Btw, Howie, your engine bay looks clean as!! I could just see it, but gee it looks clean lol.
Edited by CRoNic...
:D i droped a little dose next to your house 2day....who ever drives the monaro knew it was an rb i think... thaught i was u lol
Whoa, and to think not all that long ago I think it was Chef that banned that word, something to do with VL's and their drivers.
i pray that they do and get a better entry parking facilities and move closer to me :D
Spotted/Drove next to a White R34 GTR Heading up Unley Rd this evening (5:30), had Bronze TE37s (I think, never got a good look at the wheels still), a powerplay imports sticker on drivers side 1/4 window, and lowered slightly so guard sat level with the tyre.... BLOODY NICE RIDE! When I first saw the rear end I thought it was the chef, then realised that it didnt have the CF bonnet and younger driver.
Are you saying I'm a younger driver?? :D
chef stagea, wash your mouth out with soap. Let us never mention the "d" word again.
Sweet as.. had problems with my piping, so they gonna make up some new ones.
I was wondering the same thing actually.. especially after seeing Wheelworx new joint in the city. They're packed out over at boostworx.
Thanks buddy :D Just had new silicone pipes through the engine bay over the weekend.
Oh forgot. I spotted a Red 33 with white Starcorps with the places "GTNLOOS" or something close to it pulled over on Findon Rd the other night. I think it was monday night.
Yeh woulda been me, on a break at work couldnt resist had to pull over to eat my food
Yeh i remember a gun metal grey 32 that drove past woulda been about 8 ish or so
Ah yes, parked just down from the g/fs house, walk her home from work then drive from there.
Spotted a grey 32 GTR in the macca's at seaford tonight about 7 with what looked to be 34 GTR rims (or lookalikes), looked very nice. I was in the blue VP that drove past to get a better look.
Also saw a Black 33 with for sale written all over it, big one on the back window with make an offer, was parked in the kfc at seaford.. Was around the same time.
yeh that was me in the 32 gtr nd yeh 34 gtr rims no fakey lol spotted a blue gtr in seaford maccas gtr seat covers i want some about 8 tonight
Also spotted today
about 3 pm down torrens rd a black 33 gtr with the plates 'GTR 2NV' it was behind me for a while
And about 6 pm down Pt Road a silvery champagny 34 was behind me for a while
troy, that blue 300 you saw is a mate of mines.lives around the corner from me.i think we have done well not to run into each other yet lol.
Yeah Jack ,Im surprised I havent passed ya yet..lol should catch up sometime ? and no I still haven't finished my car ..lol over the holidays hopefully
Spotted a Black R32 GTR ? on south road near Irish pub just after sunset, saw it at the last second so didnt get a wave off
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
