Oh yeah, i remember that beanie. i wanted that beanie a fair bit hey!
spotted a black 34 near the freeway on-track near mt barker around 1.30 or so pm..was on the r31 cruise that was going there..
and a black 34 4 door with black drifteks, in Gumeracha around 3.30
silver autech stag and black s15 on south road ohalloran hill about lunchtime, turned left onto chandlers hill road
and think i spotted Blazk on south road at croydon this arvo
new S reg plates (with an I in the middle), looked similar to the pics. i was goin toward torrens road with the trailer in tow
Yerp that was me, first to spot me in SA :)
Spotted a silver Stagea turning off Finniss St into Hersey Ct, Marion at 5:10pm yesterday.
Also at 7pm yesterday spotted a white R32 parked in my street.
Today spotted a white R33 waiting at the Diagonal Rd/Sturt Rd intersection around 2:45pm.
Spotted a Silver 34 going along South road near Marion on Saturday... Some ethnic guy driving. Was a huge fail when I saw he put a GTR badge on the boot on the left side half way up. And his Bob Jane special rims.
The bigger fail came from my lady passenger who said "That GTR looks better than yours."
Glass in the face was an option running through my head at that moment.
Late post but
Friday
Dark Purple S14 with vented front guards in the backstreets of Edwardstown
White R32 GTR at Holden Hill, parked behind gates on grass at a house
White Cef wiv black kit (unpainted) in Turbo tune a couple of times
Sunday
Silver Stag on states rd followed closley by a undercoverie
Blue S15 on Wheatchif rd
Monday (2day)
Yellow S15 at Moana driving down commercial rd heading towards seaford (female driver)
Black R23 (P plater) going up and down Dover st in Aldinga Beach
Black 180 at Hungry Jacks Seaford
Another black R32 (P plater) on Cherry Gardens rd
White R33 on south road (daws rd intersection) had the number "13" on the top right corner of the rear window
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
