Spotted a silver Stag, somewhere, cant actually remember where, but driver gave me a wave, first time from a Stag owner, so thanks buddy. Knodded back, dont know if you saw but yeah. Was around 5ish..
A clean as 34R with CC plates on South Road about half hour ago, thing sounded craaazy! Turned up the expressway and went onto Panalatinga Road.. Had dark coloured rims and possibly HID's?..
Also a silver 33 with smashed front end at the Fullaton/Cross Road intersection, had a head on with a VW minivan... Didnt look good..
Spotted a red stag with an sau sticker on the right rear quater window on richmond road today with cc plates. was around 1230-1245ish today. i was walking along the footpath going back to work from the servo.
To they guy with the yellow stagea with Dayz body kit at the goldengrove dog park - german shepherd named Chilli
Hi
sorry i never got your name but nice chatting with ya.
no doubt i'll see you again i need to wear out my labradoodle pup
Btw my name is Daniel - dog Diesel
he is knackered!
Flashed that black Satg with ICULKIN or what ever it is on the plates on Chandlers Hill Road, car looked good. Today about 1.30..
And spotted a grey 32 heading towards the city on the freeway, both looked at eachother going opposite directions.. Was yesterday around 2ish..
That was me on my way to work. Should have waved or yelled or jumped out infront of me. Hahaha i would have waved back.
Seen a blue s2000 slammed with white te37 in the city this morning at victoria square crossing. Burgendy red stag about 3 crossing over sailsbury highway into mawson lakes. Oh and a few days ago seen like 5 stageas around the place. Shit load of em gettin around now.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
